Results 1 to 10 of 10
Thread: Using High pH in pools
    schrody's Avatar
    Aug 2008
    Fort Worth, TX
    75
    Maybe this topic has been discussed on here but if I search "high pH" in the forums it ignores both words because they are too common.
    This is an article I read a while back and wondered if the gurus here could shed some light on it:
    http://www.poolsolutions.com/gd/hiphpool.html
    If this has been discussed before then maybe someone could just point me to the topic.
    12,000 gallons - IG - Vinyl
    IntelliFlo VF Pump
    Tagelus TA-60 Sand Filter
    Re: Using High pH in pools
    This came up before towards the end of this topic. Briefly, when Ben did that write up the relationship between PH, TA, and CO2 outgassing was not understood. With that new understanding we can get the same results Ben was getting while using lower PH targets than he was using.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    He doesn't mention swimmer comfort anywhere in the article. The first thing Bioguard ever "taught" me was that "the pH of the human eye is 7.5" which is why they push 7.4-7.6. Obviously you can adjust your CSI and chlorine level to suit a higher pH, but you can't mandate goggles. Is the eye pH thing oversold or would that be a problem in this situation?
    schrody's Avatar
    Aug 2008
    Fort Worth, TX
    75
    Thanks Jason...that answers my question!
    IntelliFlo VF Pump
    gtm's Avatar
    Aug 2008
    St. Petersburg, Florida
    201
    Quote Originally Posted by spishex
    I don't know about this situation, and the following is very qualitative, and at best one data point, but my experience is that the pH matters a great deal for eye comfort. Since I took over my pool I starting logging everything that went into the pool, and I also test way too much. Just saying that I think my data is reasonably good.
    My humaniform pH test strip (i.e., my 10-year old) seems to be quite reliable. He won't set foot in any pool but ours without goggles, and the aversion to ours was also true in the "Service by Pool Fool" days. I monitored eye complaints and readings and found out fairly quickly that if I had it at 7.5 the goggles were thrown on the deck. 7.4-7.6 wasn't bad, but outside that range I got complaints. I've since been checking that daily and adjusting to stay in the 7.4-7.6 range, and as close to 7.5 as I can get.
    BTW, I didn't know about the pH of the eye being 7.5 before reading the post from spishex, but this is FWIW only.
    Cheers, Gary
    15,000 gal. IG fiberglass pool w/ 1 hp Hayward Max-Flo and 250 lb. Hayward sand filter
    Located in St. Petersburg, Florida, and enclosed in a birdcage
    30,415
    Good reading.
    Way back on PF, I thought I remembered reading that 7.8 pH was normal for humans.
    Does anyone know if it varies from person to person?
    Actually, I know some folks whose personalites are about 5.8 pH but I'm not sure about their eyes.
    Mar 2007
    San Rafael, CA USA
    12,082
    A quick Google search turned up this link with a pH of 7.50 with a standard deviation of +/- 0.23 so out of 20 people, 63% of their 40 eyes had tears that were with a pH from 7.27 to 7.73. From this link six people had 7.50 +/- 0.16 (SD). So it does vary a bit from person to person, but the average is around 7.5.
    From what I have seen, the amount of eye irritation is not symmetric around a PH of 7.5. That is to say that many people are comfortable at a PH of 8.0, while fewer people are comfortable at a PH of 7.0.
    gtm's Avatar
    Aug 2008
    201
    I hope I'm not "hijacking", but the post from spishex had some resonance with my experience, so I couldn't resist.
    JasonLion's question about the symmetry of the response is something I can't address. I haven't let it vary that much, and probably won't.
    Concerning Duraleigh's question about person-to-person variability, I was (as usual) being a little facetious talking about the 10-year old "test strip". My 16-year old stepson and I have had similar responses. But that might be genetics at work, or autosuggestion (?), as the psychologists might say. Again, just FWIW.
    Finally, concerning,
    I can't remember who came back with this line first, but "I resemble that!"
    Cheers, Gary
    Guest
    Read my comments in the above thread that Jason referenced and remember that it was all started by United Chemical whose bromine based products are more effective at higher pH. Coincidence? I think not!
