Results 1 to 9 of 9
Thread: Automated or Manual for Solar Heating - New build in FL
    May 2015
    Land O Lakes, FL
    527
    New IG pool build in Florida. 2 Story House with large roof facing SSW, will have a Pentair VS Pump.
    PB says " The automatic control for it is a waste of $$ " - I have not spoken to him yet to find out why he says that but plan to.
    On a 50k total pool build another $300 is not that much.
    I have spoken to 2 people that have solar. One has automation and likes it, the other does not believe in automation.
    Is a stand along solar automation system worth it?
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Automated or Manual for Solar Heating - New build in FL
    Yes, absolutely. Unless you are there to shut off the solar valve every time it rains or gets cloudy. Solar panels will cool your pool if the temp is lower than the pool water. I manually ran my solar for a while by trying to guess whether I would get heat or not based on the weather forecast. Some days my pool would be cooler after work than before work. It has been a couple of years but my pool was around 8 degrees warmer on average after adding the Solartouch. Although, I would get the Suntouch if I had done better research.
    May 2014
    Rhode Island
    11
    I agree, go with automation. We just put in solar and originally I was against putting in the automation. But the solartouch is very simple and works great with the pump. And our pool would constantly go over temp if we didn't have it.
    Aug 2015
    San Diego
    67
    Nice discussion, thanks.
    How to know how many sq ft of H2O panels are needed to warm per degree and 1,000 gallons ? Ballparking of course.
    I'm in the San Diego area. Lots of sun here, low humidity and not much rain.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Personally I would not let anyone that thinks a solar controller was a waste of money in Florida where thermal thunderstorms are common in the spring anywhere near installing a solar pool heater.
    38,274
    You usually want 50-100% of your pool surface area in solar area. Depends on sun exposure to your pool as well as solar panel orientation.
    Aug 2015
    San Diego
    67
    Thanks JB.
    May 2014
    Rhode Island
    11
    We have a 30k gallon pool in Rhode Island. I spoke with a bunch of solar professionals about coverage. We could only fit 50% coverage on a south-east facing roof. I am happy to say that it has truly transformed our pool. We use the pool every day now. We have the system set to 90, and it's hit that almost every day since it was installed in mid June. Some mornings it hits 90 before noon, so the controller is necessary IMHO. We are thinking of turning it down to 87-88 as it can get cold when you get out. Best investment we have made in the pool.
    May 2015
    Land O Lakes, FL
    527
    Thanks everyone, definitely doing automation
    Matt
