Thread: Please help
    Aug 2015
    Baltimore, Maryland
    2
    Please help
    I live just outside of Baltimore, MD. Last summer we had a bit of yellow staining that seemed to disappear when I applied a Vitamin C tablet to it. We opened the pool early this year, in April, to deal with the staining. We bought Stain free, applied it twice, and the stains didn't go away. We shocked the pool, it, did not get better.
    When we opened the pool there was a new stain on a step in the shallow end.
    Our pool company came out and said it looked like a leaf or something natural/biological. However, to us, it seemed to almost be coming from inside the plaster.
    As as for the yellow staining he said things like discoloration motling, discoloration of plaster. He also said we need to remove scale and to look for products called Scaling Connie, Dr. 40, hydro quest and scale free. We didn't do any of that because we thought maybe we would redo the plaster instead and he said some of these products are difficult to find.
    In/around June we had green algae growing all over. We took in samples a few times and we couldn't keep our chlorine level up. We treated our 35,000 gallon concrete pool with fifty five pounds of chlorine. It killed all of the algae.
    We took samples in throughout the summer and our numbers were good. On occasion our chlorine was low but it never required more than a small bag or two.
    Now, over the last few weeks we have a spider web type yellow stain around the pool (see photos). It does not come up with brushing. We took a water sample in today and were told we again have zero chlorine.
    The pool is 10 years old. We have never had a problem maintaining chlorine until this summer. The pool is mineral/salt.
    if anyone has any idea what's going on, please help. We had another company come out last week who said it could be mustard algae however we are not in the typical geographic region for mustard algae and it does not disperse when we sweep it.
    Thank you again and again!!!!
    Aug 2014
    Northern IL
    4,615
    Re: Please help
    Try putting another vitamin C tablet on it and see what happens. Sorry no one replied earlier.
    Jun 2014
    14,991
    Re: Please help
    Welcome to TFP! I suspect that before anyone will be able to give you some concrete guidance, we will need a full set of test results from your TF-100 or K-2006 test kit. That's going to be the starting point of it all. We never rely on pool store testing as it usually has errors, and test strips are basically worthless. If you don't have ether of the kits above, you can get it here at TFTestkits.net.
    In addition, please add your pool & equipment info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later.
    Lastly, while we wait for those results, you might want to review these pages which may help you a bit:
    Pool School - Metals in the Water and Metal Stains
    Pool School - SLAM - Shock Level And Maintain
    Let us know if you have any questions.
    Aug 2015
    Baltimore, Maryland
    2
    Re: Please help
    Thank you very much! I'll order the tests and in the meantime try the Vitamin C tab again and read the articles/forums.
    Aug 2014
    Northern IL
    4,615
    Re: Please help
    Excellent. You will never regret purchasing your test-kit!
