Intellitouch SPA Error; when heater is required
ewsb
May 26, 2007
77
Northern VA
I have a raypak heater connected to the pool. When the pool function requires heat is activates the heater perfectly and everything is fine.
In order to establish a second heating cycle at a higher temp, I have connected the SPA function to the heater. When the SPA function calls for heat, I get an error. Any ideas on what is missing?
Thanks
Sean
What error are you getting? Do you have a split system, two pumps/filters? Normally the heater is connected to the automation system and then the heater itself is put in "remote mode" and the temp setting on the heater is set to the highest it can be set, 104. Then you use the automation system to control what temp you want it set to.
