Thread: Intellitouch SPA Error; when heater is required
    Northern VA
    59
    I have a raypak heater connected to the pool. When the pool function requires heat is activates the heater perfectly and everything is fine.
    In order to establish a second heating cycle at a higher temp, I have connected the SPA function to the heater. When the SPA function calls for heat, I get an error. Any ideas on what is missing?
    Thanks
    Sean
    Sean
    15 x 30 gunite pool with Riverflow Professional 12miles per hour flow (10HP silent ABB pump) to make the entire pool flow - Pentair Intellitouch i10 - Heat pump AquaComfort 110 - Raypak 399k Digital Gas Heater - Pool Pilot Digital SC-48 - Pentair FNS Plus 60 - Polaris 3900 Sport Cleaner on booster pump
    2 x Pentair Intelliflo pumps - one for filter (VF) and second for Venturi Pool Jets (VS) and Jandy 6 set deckjets - Pentair PG2000 Fiberoptic lighting - Automatic PoolCover (Brown) by Pool Cover Specialists
    Winter Pool Bubble by Ameri-Dome
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Intellitouch SPA Error; when heater is required
    What error are you getting? Do you have a split system, two pumps/filters? Normally the heater is connected to the automation system and then the heater itself is put in "remote mode" and the temp setting on the heater is set to the highest it can be set, 104. Then you use the automation system to control what temp you want it set to.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
