Thread: intex 2500 gallon pump
    Aug 2015
    huntsville, AL
    1
    does anyone have a pic for the input wiring? my power cord seems to have met a lawnmower
    38,251
    Re: intex 2500 gallon pump
    Welcome to TFP!!!
    What exactly do you need to know? I would assume there on 3 wires in the cord.
    38,251
    Quote Originally Posted by Paul_M View Post
    One wire is ground, should be yellow or green with a stripe on it. (or another two colored wire) The other two have only one color: brown and blue for example. Since it's AC the ground wire must be reconnected to the ground wire. The other two don't matter, but it is good practice to not mix colors.
    This can not be correct. The wires most certainly matter for 120v applications. There is a hot, neutral, and ground.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    It is correct. AC means that negative and positive alternate. In the USA you also have nonpolarized plugs, I'm clueless why you also have polarized plugs. (We have symetrical 220v sockets for both grounded and nongrounded plugs.)
    nonpolarized plugs have been out of standard for decades.
    Jason is correct in stating that it does matter in U.S. 120v applications. While the hot/neutral alternate 60 times a second, where those wires are connected inside a panel makes a difference. All "white" neutral wires are connected to a common bus bar in the panel. If you swap the wires downstream of the panel you have the possibility of applying voltage to the neutral bus causing a back feed.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    The electrical color codes in Europe and US are different.
    Paul is staing the code in Europe.
    The color code in US for 220 is
    REd Hot
    Black Hot
    Green Ground
    for 120 the code in the US is
    Black Hot
    White Neutral
    Green Ground
    Divin Dave,
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    ^^^^What he said^^^^^
