Results 1 to 17 of 17
Thread: Clear rigid PVC
    rdshackleford's Avatar
    Jul 2015
    Coatesville, PA
    116
    Clear rigid PVC
    Since the summer season here in the northeast US is waning, I just wanted to post about a customization I made to my system this season that worked out very well. I replaced the PE, PVC, and ABS pipes around my pump and filter with clear rigid schedule 40 PVC pipe. The installation was easy, and the payback came in droves. When I operate the pump valve and motor control, I get instant feedback on what is going on. I don't have to run to the return or waste line endpoint to see what is happening.
    https://goo.gl/photos/Zu2xdEyaXVBFkMXi8
    I bought the pipe for about $20 plus the solvent. Also, the old school Hayward S240 filter has a clear polycarbonate dome on top that also helps. The 70's era S240 I had at my previous house did not, and I appreciate the 3 decades old upgrade. LOL.
    29,085.1 gal inground grecian vinyl, Hayward Super Pump VS, Hayward S-240 sand filter, Dolphin Nautilus Plus (aka Agador Spartacus), Taylor K-2006 kit, nice pool brush, crappy leaf net, frogs
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Clear rigid PVC
    Interesting. It is almost like if our skin was transparent and you could see inside your body.
    Where did you get it? What are the specs on it? I've never heard of it before.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Clear rigid PVC
    Thats neat.
    I didnt know there was such thing as clear schedule 40 either. Ive never seen any.
    Divin Dave,
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Clear rigid PVC
    I have been trying to find some also... you have to let us know where you found some..
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Clear rigid PVC
    well....it' definitely out there. Just when I thought I had seen it all!
    Clear PVC Pipe Fittings - ALSCO Industrial Products, Inc.
    Divin Dave,
    Jul 2013
    Fletcher, OK
    3,353
    Re: Clear rigid PVC
    now that is a great find love
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Clear rigid PVC
    Wow....the fittings are EXPENSIVE...pipe ain't so bad. Neat stuff.
    ----Chris----
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Clear rigid PVC
    I love clear PVC. We use it sparingly, but in some situations it's a wonderful thing to have. Nice job!
    Essential Links:
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Clear rigid PVC
    Quote Originally Posted by Agent99 View Post
    Your not Kidding! A 1.5" 45% clear elbow is $30.58- Thats $30 more than a white elbow!!
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    30,403
    Re: Clear rigid PVC
    I knew of it's existence but for me, at 8.47/lineal foot for 2", that won't fit well in my budget. I also saw $34.00 for a 2" 90.
    Jul 2015
    Coatesville, PA
    116
    Re: Clear rigid PVC
    I bought 8' of 1 1/2" pipe for $27 at Zoro. Item # G1790476. The specs are on their website.
    Also, I use flex PVC for my drain line. That comes in handy when the spider gasket on my multiport valve insists on leaking a little while in filter position. I just throw the drain line over to the edge of the pool.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Clear rigid PVC
    Agree. 2" plain old boring white opaque PVC is around 80 cents/lineal foot.
    ----Chris----
    Dec 2014
    Riverside California
    482
    Re: Clear rigid PVC
    How about UV? I know that clear PVC tubing is NOT UV resistant as is the black stuff.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jul 2015
    Coatesville, PA
    116
    Re: Clear rigid PVC
    Dunno. Mine is in shade. Here is the brochure for the product. http://www.thermoplasticprocesses.co...chure-2011.pdf
    If you are concerned with UV from sunlight, you could cover it with split foam tubing. How about a Super Noodle to make it festive?
    Quote Originally Posted by gary300 View Post
    Donldson's Avatar
    NW Ohio
    2,881
    Re: Clear rigid PVC
    Are we talking UV resistance out of fear that the PVC will get cloudy, or because of the water being exposed to UV?
    Hmmm, now that I think of it that gives me a great idea. Clear PVC and some mirrors and boom, "All Natural UV Sanitation System"! No bulbs to replace, no electricity, and it cuts your chlorine use in half* Recommended by the most honest pool store employees!
    *Statement has not been evaluated by anybody who knows anything about pools.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2014
    Roseville, CA
    343
    Re: Clear rigid PVC
    I have a clear check valve on my solar system that is now opaque due to sunlight. But you have shade, so I hope you have better luck! It looks totally cool!
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Clear rigid PVC
    Quote Originally Posted by Donldson View Post
    I dunno, my pool gets hit by the sun's UV several hours every day.
    ----Chris----
