Results 1 to 15 of 15
Thread: Pump running time
    Jul 2014
    Bowling Green, KY
    45
    Pump running time
    I'm just curious how long everyone runs their sand pump?? Do you run it 24/7, 8 hours, 10 hours, or 12 hours?? Do you run it overnight or during the day? I'm currently running mine 12 hours (10am-10pm) and the swp for 9 hours. Of course, summer is almost over and we will be closing it next month, so really just info for next season.
    22X56 Intex Deluxe Easy Set Round
    14" Intex Sand filter
    Intex Saltwater pump
    Jun 2014
    15,011
    Re: Pump running time
    I suspect you will get bombarded with many different times from forum members all based on their pool's specific requirements. In the meantime, I wasn't sure if you already saw this page: Pool School - Determine Pump Run Time. Good luck!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have a Variable Speed pump. I also have a Saltwater Generator and the SWG is on a timer.
    Because lots of stuff blows into my pool, and the fact that I just like to see the water moving, I run my pump 16 hrs a day, but only at 1200 rpm which means cheap electricity bill. My timer tuns on my Saltwater Generator for 3 hours in the morning, then off, then 3 hours again in the evening so that my FC stays up where it needs to be.
    Divin Dave,
    Jul 2014
    Bowling Green, KY
    45
    I have several large trees as well (stupid leaves and sticks!) and now that it's getting towards the end of summer and it's dry, the leaves are falling much quicker. We rarely use the pool during the week now that school has started, so I was thinking about changing the filter times to evenings/over night when there is less electricity being used. I love having pool, however, I HATE my electric bills in the summer.
    mas985's Avatar
    Pleasanton, CA
    11,737
    These recommendations apply to all types of pools and filters: Pool School - Determine Pump Run Time
    Mark
    kk_isme's Avatar
    Aug 2015
    North Central Texas
    108
    I run mine during the day when I am home. Evening if I'm gone during the day. Probably for 4 or 6 hours. I have had bad experiences with hoses cracking open during the night or while I am out and it is a huge mess and waste of chemicals and water, so I like to run the filter when I am home and can react quickly to any problems.
    14,000 gallon above ground 24ftx56in round vinyl overlap liner steel wall sand filter 1/2 hp pump heavy lime in city water morning shade
    May 2012
    Montville NJ
    545
    Four hours a day - 6 AM to 10 AM. I test and add any necessary chemicals before work in the AM.
    I would like to change it to 6AM - 8 AM and again from 4 PM to 6 PM - just to pick up some of the leaves that drop in during the day (I don't get many) but I have been too lazy to get additional stops for the timer.
    I do plan on going to a SWG next summer, so that is going to change things up a bit, but the 4 hours a day is enough to keep my particular pool very clear.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Aug 2015
    Chesapeake, Virginia
    10
    Put mine on a timer, runs 12 hours a day 8:00 a.m. - 8:00 p.m.
    Artesian Riverview 24 Ft Round 54" Wall Steel Pool (Dec 2008)
    Approx: 13,500 Gallons
    Sta-Rite 200lb Sand filter and 1hp Sta-Rite Pump
    Wedding Cake Steps
    Frog Chlorination system
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    439
    According to my pump's flow rate and pool volume, it takes 7.91 hours to turn over my water once, so I run my pump between 1pm and 9pm. It will typically go on earlier on the weekends if we are taking a dip before 1 o'clock.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    mas985's Avatar
    Pleasanton, CA
    11,737
    Turnovers are irrelevant and should have no bearing on your run time. Please read pool school: Pool School - Determine Pump Run Time
    Mark
    Husky25's Avatar
    Jun 2015
    439
    Hmm...Interesting.
    8 hours is still shorter and cost less than the 12 hours I used to run it (recommended for Baquacil), but 4 hours doesn't really give me a warm and fuzzy feeling either. While my pool is in the sun pretty much all day, I have a backdrop of woods just outside the fence line, just a few feet away. I get leaves in the fall and cottonwood seed (and what look like buck-eye flowers) in the spring.
    Perhaps I'll experiment with runtimes, but on the other hand I like to have the pump on while the pool is in use and I don't want to overriding the timer each I go for a swim. Electricity cost is not as much of a concern it was in years past, due to our recently installed solar panels.
    Chris
    mas985's Avatar
    Pleasanton, CA
    11,737
    Certainly for debris removal you may need some more run time but for just chlorination and circulation, you can get away with very little. In fact, the study in my signature shows that the water quality in the many pools studied did not improve substantially after only 2 hours of run time.
    But even with solar panels, it still "costs" you the potential revenue you could make off the solar panels instead of running the pump.
    Mark
    May 2012
    Montville NJ
    545
    Quote Originally Posted by Husky25 View Post
    Hmm...Interesting.
    I started with 8, and backed it down from there in about hours increments. Two hours gives me a pretty consistent mix when I add bleach. but 2 hour is really pushing it. I also like to run it 4, because it does better at eliminating the temperature layers that happen from my solar cover (there can be 8 to 10 degrees between the top and bottom of the pool)
    If I have a large bather load, such as a party, I will kick the filter on for some extra time. My pool is pretty much in the middle of the yard, so I don't get that much debris in it, unless it gets very windy.
    Zodiac Wahoo
    Husky25's Avatar
    Jun 2015
    439
    Thanks, Mark
    Solar panels mitigate energy costs. They do not eliminate them. Companies are not allowed to "design" a system that would provide a net positive generation over a given year. They take a sample of your readings from the prior year and extrapolate your consumption. On the other hand, they cannot control the weather or a panels' efficiency. There are certainly some months (March, April, and I suspect September and October) where you build up a credit on generation and delivery, but there is still a fixed Customer Service Charge that cannot be avoided.
    That is neither here nor there. The OP's question was how long we run our pumps. I answered it. It appears that I am mistaken on my basis for running that long, but at this point, it is what it is. I read the study in your sig. As I said. Interesting. I'll look into adjusting my timer and see how it goes.
    Dave-
    Temperature layers is why I like to run the pump while the pool is in use.
    Chris
    mbuice's Avatar
    Jul 2014
    Denton, TX
    95
    I have a 2 speed pump and I leave mine on 24/7. I've only had it for 4 months, but I compared my energy bills to last year and the increase was less than $20 per month. I should point out that my pool is in full sun 11+ hours/day and adjacent to some large trees that dump leaves into it.
    18 X 34 AGP 7ft deep end, 22,300 gallons. 250lb sand filter, 2 speed 1.5 hp pump. TF-100 Test Kit.
