Thread: How to measure DE for filter
    Aug 2013
    Hilton Head, SC
    133
    I'm not sure I'm using the correct measure of DE when I reload my filter after a backwash. I'm using the 1lb 13oz blue plastic Maxwell coffee containers. My filter is a Pentair FNS Plus 36. How many containers of DE should I use on startup (after I have cleaned the filters at the start of the season) and how many after I backwash during the season?
    I am seeing very tiny pieces of debris on top of the pool, and am worried that the filter is not loaded properly. Of course, the pool sits under a live oak, and there is constant material falling in especially during a rain storm or even mild winds.
    thank you,
    ed
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    Re: How to measure DE for filter
    Each pound is about 48 fluid ounces (volume). Your filter needs about 4 lbs on a fresh start and about 3.5 lbs after a good backwash.
    Support the site
    Jun 2015
    Wildomar, California
    423
    Also, 1lb of DE is equal to 2 1lb coffee cans. DE is 1/2 as heavy as coffee.
    Aug 2013
    Hilton Head, SC
    133
    Quote Originally Posted by OldPoolMan View Post
    This is good info. So I can calculate that a 1lb 13oz container is actually about 15 oz of DE, so if I need 3.5 lbs to recharge after a good backwash, I'll need roughly 4 containers of the containers.
    Is there a danger if I over charge the DE?
    thx
    that is, "4 containers of the DE"
    The amount of de isn't critical, but you should try to get close to the recommended amount.
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I weigh it on a postage scale. That way I know I have the right amount.
    chiefwej
