Results 1 to 20 of 20
Thread: Cloudy water
    Aug 2015
    Lexington ky
    10
    Cloudy water
    I've been fighting cloudy water since hooking up my new sand filter and swg. Water was totally green before starting. I've gotten it to an almost clear look but still cloudy on bottom. Took a sample to pool store and of course he wanted to sell me 150.00 worth of fix it stuff and said my chlorine almost was non existent. I added bleach and stabilizer to boost it thinking my swg wasn't keeping up because it was so green to start with Then I just got my T100 test kit today. Tested water my chlorine level must be off the charts because I did the chlorine drop test and 40 drops in it was still a purplish pink. And I did the one in the basic test kit, the ph looked normal 7.5 but again the chlorine didn't even match the color on the kit. The colors on the kit are greenish yellow , my sample is almost orange.
    And my alkalinity test is off too, says it should turn red it's more like a light yellow. My cya is 65 . Any idea where I'm going wrong ???
    5000 k AG hard plumbed intex , intex sand filter pump&SWG cg-28679, Hayward in wall skimmer, Tf-100 test kit.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Cloudy water
    Welcome to TFP!
    When you did the FAS-DPD chlorine test, what sample size did you do? You want to do the 10ml sample size so that' each drop is .5 FC rather than the 25ml sample size where each drop is .2
    Support the site
    Aug 2015
    Lexington ky
    10
    Re: Cloudy water
    I did the 10 ml sample in the cylinder . I just tested my CL and it's coming up high at around 600. Could that cause the cloudy water.
    Jun 2014
    15,103
    Re: Cloudy water
    Well, a few tings you might want to consider:
    1 - If your FC (chlorine) really is high, don't bother with pH testing. It will be off. Don't test or adjust with high FC.
    2- You have a TF-100, so don't bother with the pool store. In fact, post a full set of numbers for us now so we can make a better informed decision.
    3 - Green before (changing a little by now) sound like algae. Chlorine/bleach via Pool School - SLAM - Shock Level And Maintain is the way forward.
    IF your CYA is 65 (say 70), then SLAM FC level is 28. Follow the SLAM page and stay at 28 until you pass all 3 SLAM criteria. Let us know if you have any other questions.
    Aug 2015
    Lexington ky
    10
    Re: Cloudy water
    CH calcium hardness not CL . Sorry
    Jun 2014
    15,103
    Re: Cloudy water
    600 FC test doesn't make sense. I suspect there's a testing error or confusion somewhere perhaps.
    Ahhhh, gotcha.
    Jun 2014
    15,103
    Re: Cloudy water
    High CH can have an impact in some situations, but normally isn't a factor for AG vinyl pools. And since you stated the water was green, we already can assume you have algae growing. I would suggest implementing the SLAM first to remove the algae, then "if" the water still appears cloudy, we can address that specifically later.
    Correction - you DO have a SWG, so the high CH may be an issue for that. But still suggest the SLAM at which point the SWG should be turned-off anyways during the SLAM.
    Aug 2015
    Lexington ky
    10
    Re: Cloudy water
    Yes I have a Intex SWG sand filter combo
    Jun 2014
    15,103
    Re: Cloudy water
    While you are doing your SLAM, please see this thread on SWG pools with high CH: Any downside to running an SWG pool with fairly high CH?. Hopefully this will help you afterwards.
    And another good discussion: SWG vs. BBB for High CH Water
    Aug 2015
    Lexington ky
    10
    Re: Cloudy water
    I figured out my FC is 43
    Jun 2014
    15,103
    Re: Cloudy water
    Oooh weeee! That's up there. Just let it sink back down on it's own. Shouldn't take too long. Then you can keep it at your ideal 28 SLAM.
    Aug 2015
    Lexington ky
    10
    Re: Cloudy water
    Ok. I have been reading on how to SLAM , I thought slamming was getting your FC levels higher . Sorry if this is a dumb question. I'm new to pool chemistry .
    Jun 2014
    15,103
    Re: Cloudy water
    Not dumb at all. Best to be clear on your first SLAM. Very common. But now you can put it all together by looking at the Pool School - Chlorine / CYA Chart. Your CYA (rounded-up to 70) makes the SLAM FC level 28. Now that's all you need to focus on until you pass the 3 criteria. Good luck, and if you have any questions along the way, feel free to ask.
    Aug 2015
    Lexington ky
    10
    Re: Cloudy water
    Do you recommend adding any DE to my sand filter to speed up the process?
    Jun 2014
    15,103
    Re: Cloudy water
    That certainly can be an option, but I would recommend to hold-off for now. Let your system filter and process what it can normally since you will be doing several backwashes anyways. The sand should grab the larger dead algae debris. Towards the end of the SLAM, some people will add DE to assist with the fine-tuning and water clarity. But I suspect right now is just a bit too soon. I may however, get over-rided by another opinion.
    Aug 2015
    Lexington ky
    10
    Re: Cloudy water
    How often should I backwash the filter?
    Jun 2014
    15,103
    Re: Cloudy water
    You may see a few variances here based on personal preference, but basically when your psi raises anywhere from about 5-10 psi from normal clean pressure. Then it's probably time to backwash.
    Aug 2015
    Lexington ky
    10
    Re: Cloudy water
    Update , Water is now crystal clear.
    Jun 2014
    15,103
    Re: Cloudy water
    Outstanding! Another success story!
  20. Back To Top    #20
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Cloudy water
    Woohoo!
    Backwash when the filter pressure rises 20-25% above clean pressure.
