Thread: leaking pool pilot check valve?
    Jul 2015
    Indianapolis/Indiana
    9
    Don't know if it's one piece or assembled.......I have a Pool pilot digital SWG and I have the horizontal check valve that is a white plastic pipe with the transparent plastic in the middle where the spring is.........anyway, I have a slow leak coming out where the transparent and solid plastic meet.........I'm guessing it's a crack in the single unit but I don't know. Anyone have any thoughts? I'm thinking of using some compression tape to try to stop this slow leak.
    pete
    27,000 gallon in-ground
    vinyl, heated by Rheems
    use DIG-220 pool pilot SWG salt system: single manifold, RC-52 cell
    Coverstar automatic pool cover
    Ft Lauderdale, Florida
    1,455
    Re: leaking pool pilot check valve?
    If its under warranty, I'd recommend contacting the factory. If its out of warranty or not as a result of a defect, you can use A&B Epoxy Putty. If you go this route, make sure you stuff the epoxy into the gaps.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
