Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: Muriatic acid??
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    Muriatic acid??
    New pool, new water.. with local testing kit pH is 8.2 and wanted to add muriatic acid as I read in the pool school. but when I went to buy it at Problem with link. Removed by moderator the staff there strictly said no to use IN the pool. They say its for cleaning outside the pool(conceret) ..
    So finally got Pool Time 5 lb. pH Down-23320PTM - The Home Depot .. is it ok to use this? this is in powder form.. I can put it in front of a return.. Kindly suggest ..
    Thanks
    24k IG vinyl , new (not any more)pool, new ( not any more) water Hayward super pump and sand filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Muriatic acid??
    The people at HD don't know what they are talking about. Use the muriatic acid. The powder can settle on the bottom of the pool and damage the liner.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,106
    Re: Muriatic acid??
    You can get the pool kind at the Lowes in E. Brunswick
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    Re: Muriatic acid??
    Quote Originally Posted by JohnT View Post
    Thank you for your reply.. But what if I mix it in a bucket with water and then pour it in front of the return?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,106
    Re: Muriatic acid??
    That's what it says to do under "recommended chemicals"
    It does add some sulfur, but should be fine until you can get MA.
    Dry acid is not recommended if you have a SWG
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Muriatic acid??
    All the big box stores should carry it, usually in the paint department.
    Shop Crown 1-Gallon Muriatic Acid at Lowes.com
    Klean-Strip 1 gal. Green Safer Muriatic Acid-GKGM75006 - The Home Depot
    http://www.menards.com/main/paint/so.../p-1479906.htm
    The stuff Ace Hardware and Walmart carry is more expensive but it's supposed to have reduced fumes. Important if you have respiratory problems or just hate getting hit with the fumes.
    Certol International Acid Magic Muriatic Acid Replacement - Pool Chemicals - Ace Hardware
    Klean Strip Green Muriatic Acid Gallon - Walmart.com
    Solar Blanket, Well Water, Borax Added. 68
    Mar 2015
    peoria, az
    57
    Re: Muriatic acid??
    pabeader - Why is Dry Acid bad for SWG?
    (Started 4/20/15) 32' x 16' In-ground Presidential Pools(3-5-4) 14K gallon salt water pool, Pebble Radiance Kona Blue, Pentair Inteiliflo pump, 420 Cartridge filter, Q-360 in-floor cleaning, Eclipse drain, 2 Spectrum 360 LED lights, Grotto w/waterfall, Trazocrete table with bench seating, 2 deck jets, Baja step, 400 sq ft acrylic lace deck - Sonoran Stone.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,106
    Re: Muriatic acid??
    i believe it promotes scale buildup due to the sulfur buildup.
    30,426
    Re: Muriatic acid??
    Generally speaking, sodium bisulphate is acceptable but not quite as good as muriatic. It's issue is that it leaves sulfates behind where muriatic leaves NOTHING.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Muriatic acid??
    Muriatic Acid leaves behind chloride salt, but that's essentially innocuous. The problem with dry acid is if you use a lot of it and build up sulfates then these can be damaging to plaster/concrete surfaces and as noted can be detrimental to SWG cells.
    Jul 2015
    South Africa
    8
    Re: Muriatic acid??
    Well what do you know you learn something new everyday.
    +- 45000 Litre IG, Fibre Glass Pool, 1 HP Pump, some sort of Sand Filter, Sunny South Africa, TF-100 test kit
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    Re: Muriatic acid??
    Thank you all.. I did see Klean-Strip 1 gal. Green Safer Muriatic Acid but then I that it word b diluted like in case of chlorine (scented etc).. I will return old one and buy this.. I could have asked here before buying, but dint want to be like a 4 yr old asking all sorts of naive questions.. Thanks again..
    jwhop3's Avatar
    Jun 2014
    Rocky Mount/Virginia
    78
    Re: Muriatic acid??
    When you measure out your Muriatic Acid, you need to deal with it ASAP, you don't want to be mixing it in water, fiddling around with it. Get in the pool as quickly and CAREFULLY as you can.
    It's when you try mixing it in water that it reacts and hits you with the yellow cloud. You donwannanunnadat.
    14,000 gallon Fox Lagoon, ingound vinyl
    PacFab Sand filter
    installed April, 2002
    Frog inline chlorinator
    Town water
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Muriatic acid??
    My two cents on adding acid: DO NOT measure outside the container, especially on a large pool, like yours. If Pool Math says you need 30 oz of muriatic acid, take the lid off the container, lower it into the water with the spout/opening still out of the water and pour in about 1/4 of a jug, maybe a little less. Of course, as recommended in Pool School, in front of a return jet with the pump running. Pour slowly. Make sure the wind is not blowing in your face. Fumes are dangerous and can catch you off guard. 30 minutes or more later, recheck your pH.
    Measuring in another container is not necessary with a large pool and only exposes you to more risk with MA. The lower concentration, lower fumes, "green" MA available isn't quite as bad for fumes but use the same caution.
    Isolated Spa - 345 Gallons
    Jul 2015
    Kentucky
    1,126
    Re: Muriatic acid??
    Remember Safety 1st ALWAYS- If you premix the liquid acid, or when diluting it in powder form, ALWAYS add the acid to the water, not the water to the acid, because it can splash back on you, and cause burns. Wear goggles or sunglasses to protect your eyes, keep it away from your face and other body parts, and do Not breathe the fumes. Pour into the deep end of the pool if you have one or in front of a jet to quickly disperse it. Avoid getting it on metal, or decking. If it should splash on you or the deck, etc. rinse it off immediately with water.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Jul 2015
    Kentucky
    1,126
    Re: Muriatic acid??
    Quote Originally Posted by JVTrain View Post
    Absolutely JV. Just don't do unnecessary things with it if you don't have too.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,106
    Re: Muriatic acid??
    Don't do like me.
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    Re: Muriatic acid??
    Thanks.. One more question.. I thot its better I confirm it with u guys before I make another mistake... As this is a new pool I am assuming the CYA would be 0 ( my tf-100 arrives to tomorrow) , as per pool math I have to add 122 oz of granulated CyA if I want it to be 40. My question is I have a measuring cup that has marking either in ml , cup or pint. So if I do the calculations in cup it says 4.23 pints or 8.46 cups.. Is that calculation good as I don't want to raise the CYA. Thanks in advance..
    Feb 2014
    Central Minnesota
    5,080
    Re: Muriatic acid??
    This is why I hate the Imperial Measuring system... There are fluid ounces and ounces (weight). Pool Math is outputting ounces for you in weight. So you need 122 ounces, which would be 7 pounds, 10 ounces by weight that you need. All solid, granular outputs from Pool Math are by weight.
    EDIT: Pool Math does also have by volume listed for granular/solid materials but I would go by weight. Some CYA granules are very fine, some are very coarse. This would affect the density when measuring by volume. Very fine granule CYA would have more weight per volume than very coarse CYA... Maybe I'm just an uptight science geek.
    Last edited by JVTrain; 08-20-2015 at 04:16 PM. Reason: Revised comments on volume etc.
  20. Back To Top    #20
    Sep 2013
    Charleston, SC
    538
    Re: Muriatic acid??
    Actually, PoolMath gives both weight and volume in their recommendations. I use my trusty kitchen scale when adding chemicals and I tried the volume recommendation and it was very close to the same amount of granular CYA.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
