Results 1 to 11 of 11
Thread: Fatty/Greasy above the waterline
    Aug 2015
    Arnhem/Netherlands
    109
    I have a question.
    I have some Fatty/Greasy feeling above the waterline.
    And if i wipe on it then (see the picture) it wil Curls unther the finger
    The spa is 6 monhts old, and i have it from the first week.
    I have clean the spa for 2 week ago (aqua clean tab) then refil.
    Thanks.
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Fatty/Greasy above the waterline
    have you tried ahhsome to clean your spa? Ahh-Some Water Cleanser, for pool, hut tub, jet bath, and washing machines
    it worked ahhsome in my tub
    Aug 2015
    Arnhem/Netherlands
    109
    In The netherlands iT is verry Verry Verry diffecult to Get chemicals.
    we have tube clean??????and cleaning tab from aqua finess.
    Factory is Caldera
    Above ground
    6 months old now.
    Jul 2013
    Fletcher, OK
    3,353
    Yes, I have been there and know it can be hard or impossible to get some things... I am not sure if something else could be used...
    Can you order stuff from Northern Ireland? There's a dealer there that sells it.
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    Dec 2014
    Sydney, Australia
    43
    Looks like skin oils/residue to me, needs more chlorine....
    Do you maintain a residual FC between uses?
    8M x 4M Inground Concrete, 40k Litres, Waterline Tiles/Quartzon, Viron P320 VS Pump, Sand Filter(Glass Media) Astral VX-9 SWCG, Heatpump w/ Solar Cover. Zodiac V3 4WD Robot. Bullfrog A8D Spa(1800Litres).
    Aug 2015
    Arnhem/Netherlands
    109
    Dibbler (Yes) i put every day ca 8/9 gram Dichloor after soaking.
    And now i have use Dichloor 1 week, i change to Bleach 25/30 ml each day.
    My Fc chloor is never to zero.
    Kias,
    I have send them a mail, i have also contact with the CEO from the company, i,m waiting.
    Factory is Caldera
    Above ground
    6 months old now.
    Dec 2014
    Sydney, Australia
    43
    Edwin,
    My first spa I had for about 5 years before discovering this site, I had similar slime problems above the waterline, since finding this site and understanding chlorine little more, I now just use 12.5% pool chlorine, dispensed into a graduated ketchup/PVC bottle, After using the Spa, depending on the use I squirt 100/150ml in, this gives me a FC of approx. 8 such a small body of water needs a bit more help to get rid of oils/sweat etc.I have an ozone generator in which chews up FC anyway, I struggle to maintain FC.
    I doubt 2/3ppm FC will clear it up, try more FC, you have CYA in there its not going to hurt.
    Simon
    Mar 2007
    San Rafael, CA USA
    12,082
    You can use AquaFinesse Spa Clean instead of Ahh-Some.
    If you haven't used the spa clean, do that first. Then see if the problem still occurs with the Dichlor-then-bleach method. If that doesn't remove the oils fast enough you can see if you can get a scum ball to absorb them from the surface of the water before they get to the spa surfaces. A scum ball is just a floating material that adsorbs oil.
    Aug 2015
    Arnhem/Netherlands
    109
    Ok thanks Chem geek.
    I had contact with the distrubituur from ahhsome, but there is a little bio killer in it and for now it is forbidden in the Netherlands.
    But they working on it, and maybey November it is for sale in the Netherlands.
    I have use Aqua finesse spa clean tab but it is not strong enough.
    Factory is Caldera
    Above ground
    6 months old now.
    Mar 2007
    San Rafael, CA USA
    12,082
    OK thanks for explaining. Yeah, Ahh-Some is pretty awesome. I'm glad they are looking at figuring out how to get it into the Netherlands later this year.
    As for surface oil, you could also use an enzyme product in the spa but here again I don't know what's available in the Netherlands for you. It would be temporary because most people don't report this problem after using Ahh-Some. There may be a small amount of skin oil when people use the spa, but what you describe sounds like more than that.
