Thread: Polaris 360 and filter pump. Will work?
    Aug 2015
    Rio
    2
    Hello guys. I read this forum for a while learning a lot about taylor kit but I've made my registration just now.
    So, I'm from Brazil but last month i was in NY and bought the Polaris 360 at there, since it doesn't ask for a boost pumper.
    But today I've tried to install it and it didn't passed the initial pressure test, when u use your thumb to test it.
    My filter pump has 1/2 hp.
    Do you guys know if that power is enough to run the polaris?
    Or that's enough and I'm doing something wrong ro run it.
    Really thanks guys!
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Polaris 360 and filter pump. Will work?
    Did you follow step 2 and go through their suggestions when you fail the pressure test? You may need to work with the other return ports in your pool in order to boost the pressure to the port where you are connecting the 360. It doesn't need a booster pump but it does need 'sufficient' (no clue what that is) pressure to work properly.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Aug 2015
    Rio
    2
    Thanks Agent99. I'm really ashamed man.
    I don't have an return at the side of my pool. I have a drain. So that would never work
    I think i had that mistake since i understood Polaris would use the pool drain to collect duties, but now i see it has his own bag for that, no need for the pool system.
    I'll made some modifications in my pool in order to Polaris works.
    Really thanks for your help bud.
