Results 1 to 12 of 12
Thread: The Pool Cleaner hangs on main drain
    Aug 2015
    Lorena Texas
    7
    Unhappy The Pool Cleaner hangs on main drain
    I just bought a two wheel The Pool Cleaner by Hayward. It is constantly getting stuck on the main drain and spends too much time in the deep end. Hayward suggested a drain cover ramp. They don't get very good reviews so I'm hesitant to spend the money unless I know something about them. Anyone here have experience with this problem and know how to fix it?
    Mike White
    Lorena, TX
    In ground 16x32 vinyl
    Hayward S244S sand filter, The Pool Cleaner automatic cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: The Pool Cleaner hangs on main drain
    I got the Zodiac drain cover ramp. It gets knocked loose occasionally, but otherwise works.
    Staying in the deep end can be caused by not having enough hose or not having the returns aimed toward the bottom.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    does it have the knobby tires on it? I do not have a main drain so cant help there... when it hits the drain does it spin around and go a different direction or does it just spin in the same spot?
    does it do it only on low speed or high speed also?
    Aug 2015
    Lorena Texas
    7
    It has ribbed tires. It looks like it gets on top of the drain and the tires can't get enough traction to move forward. I don't think this cleaner is really designed for a vinyl pool. It won't even come close to climbing the walls.
    Mike White
    Lorena, TX
    SW Indiana
    9,199
    Quote Originally Posted by txtinman View Post
    It will climb them. If it falls off the walls, change to the tires for vinyl. Make sure you get plenty of RPMs and you play with the floats.
    Aug 2015
    Lorena Texas
    7
    So what's the difference in the tires? Are the vinyl ones sticky?
    Mike White
    Lorena, TX
    Jul 2013
    Fletcher, OK
    3,353
    the vinyl ones have no bump in the tires.. if you have good suction it will climb the wall, trust me.. mine will climb my intex with the knobby tires and come completely out of the water on high but not on low...
    Aug 2015
    Lorena Texas
    7
    I might get those when it's time to replace the tires. Climbing the walls is not a big issue right now.
    Mike White
    Lorena, TX
    May 2015
    Lake Elsinore ca.
    48
    I have the same issue with the hayward navigator and was wanting to replace it with the two wheel model they offer but now I will have to rethink that if you are having the same issues.
    Aug 2015
    Lorena Texas
    7
    I just ordered these Main Drain Clip-On | Suction Pool Cleaner Main Drain Solution check them out. I'll post back here after I try them.
    Mike White
    Lorena, TX
    Nov 2013
    Ramona, CA
    46
    Had the exact same problem. To fix it I cut the end of a square eraser and put that underneath the rubber treads on both wheels to give the wheel a little bump of traction to get over that drain. With the bump on both wheels it doesn't affect it's cleaning ability. Far as the deep end is concerned make sure you have the recommend amount of tire RPM's.
    2013, IG, Gunite/StoneScapes, 16'W x 36'L x 3'-6'D, 15K Gallons, w/ 8' Spa - Pentair Intelliflo variable speed pump - Pentair MasterTemp heater 400K
    Pentair Intellibrite LED lights pool x 2, spa x 1 - Pentair EasyTouch 8 controller w/ hand held wireless - Pentair IntelliPH
    May 2015
    Kennesaw, GA
    29
    You might want to read my thread about my experience with the Poolcleaner and vinyl pools. The issue is not the tire material. Rather it is the height of the tire treads. I solved my problem by significantly trimming off the tire treads.
    Leo In Kennesaw, GA
    Older 40x20 rectangular pool
    38,000 gallons
    Vinyl In-ground - Buster Crabbe
    Pentair Chlorinator - Salt - SWG
