Thread: SI45 working?
    Jonette2's Avatar
    Aug 2013
    Oklahoma
    97
    Exclamation SI45 working?
    So, we have the Circupool SI45. My question is mainly about design. I've seen other swgs, the housings are clear and it's easy to see if they are operating. This housing is solid white and I can't tell if it's working or not. How are we supposed to evaluate it's operation? We took it off to look inside at the metal plates and we can't even seen the metal plates for all the plastic brackets. And if we decided the metal plates needed to be cleaned, how do they expect us to clean them.?
    IG Gunite pool. 30,000 gallons. Hayward type sand filter. Circupool SI 45 salt system.
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: SI45 working?
    One way to test that its working is to not add any other chlorine and see if your FC maintains or rises? Are you having problems with your FC, or just want reassurance that the SWG is working??
    Another option, and quite easy to accomplish, is to collect a water sample directly out of the pool return and you should get a FC higher than the rest of the pool water.
    Jonette2's Avatar
    Aug 2013
    Oklahoma
    97
    Re: SI45 working?
    Okay, I'll collect from the return and do a chlorine test, the reason I'm concerned is because my chlorine level isn't maintaining and I've had to add bleach. I have to admit tho that my husband loves to turn the pump off, ugh, he's a miser
    Jan 2012
    7,368
    Re: SI45 working?
    Do you have your pump and SWG on a timer? How many hours are you running it now?
    Jonette2's Avatar
    Aug 2013
    Oklahoma
    97
    Re: SI45 working?
    We put a hose on the jet and removed some water directly from there. The SWG is working very well. Now the check cell light is flashing. It seems to start flashing every 3 months we realize.
    Nothing is on a timer,because our pump is terrible to prime. Each time we turn it off, we must close the valves or we lose prime.
    Mar 2015
    Harvey, LA
    300
    Re: SI45 working?
    On our pool, we can see small bubbles coming from some of the returns when it's running. Yeah, the check cell light is a timed thing; check/clean it, then reset it.
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
