Results 1 to 10 of 10
Thread: bottom pool debris
    May 2012
    Las Vegas, NV
    92
    bottom pool debris
    So I vacuum and within a few days I get the same stuff. completed the overnight FC test and it passed. I'll get the new reading tonight but here are a few pictures to give you an idea of the stuff I collect when I vacuum.
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: bottom pool debris
    Not sure what it is. Looks to thick to be egg shells
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2012
    Las Vegas, NV
    92
    FC: 2-5 (SWG kicks in or I add liquid chlorine)
    CC: 0
    PH: 7.2-8.0 (ranges while I slowly try to get TA down with muriatic acid)
    TA: 175
    CH: 275
    CYA: 70
    Salt: 3200
    Process for cleaning the pool: vacuum using intex deluxe kit, backwash 1-2 min until clear indicator, rinse 1-2 min, back to rinse.
    K-2006 TEST KIT
    Aug 2014
    Northern IL
    4,615
    Gee. That looks like white plastic. Big pieces. No idea what it could be. It doesn't look organic in the least.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    could it be calcium coming off the SWG? do you see any scaling on the SWG or liner? could it be something blowing into your pool?
    30,432
    Deteriorating pool toys?
    Jul 2014
    Oakbank, Canada
    389
    Nasty neighbor?
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,554
    Certainly looks like calcium scaling to me.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    dakhath's Avatar
    Jul 2015
    Central FL
    35
    Could you post a picture of the yard?
    It could be something from the surrounding environment.
    Coleman 5300 gal 16'x48" AGP
    Intex Krystal Clear 2800gph Sand Filter Pump 28647EG (56673EG)
    Intex Krystal Clear Saltwater System ECO 8110
    Taylor K-2006 & K-1766 test kits w/ Speedstir and Samplesizer
    May 2012
    Las Vegas, NV
    92
    No pool toys, No nasty neighbors..lol.
    A few times I had to clean the electrolytic plates with vinegar as it has white color stuff (calcium?) and gives me an error 91, As soon as I clean it the swg continues to work for a few weeks. Could it be that it's coming from that?
    What causes/prevent it?
    K-2006 TEST KIT
