Results 1 to 14 of 14
Thread: Sj45 circupool having issues
    Apr 2015
    china grove,nc
    71
    Recent swg conversion this may with a new unit from discountsaltpools. Everything has been working well up till this week. Started getting a light on the alert panel. And isn't producing chlorine or bubbles in the cell. I removed the cell and cleaned it per the manual this past weekend. And still getting the light on after a few hours of use. Everything is in balance with the pool with tfp guides. Holding 10psi at the filter and cell is full with no air bubbles. Salt is a little high at 3400-3500ppm. I don't know what else it could be unless it's cell or control board related. Any tips or help would be great. Really hope it isn't a sign for up coming issues as it has been painless since the conversion.
    sj45 swg, tf-100 test kit, 16x32 ig 22,000 gal vinyl, Dolphin nautilus plus
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: Sj45 circupool having issues
    My SWG often throws out a "High Salt" reading to me which I know is wrong because I test my salt with the Taylor's K-1766 kit. I ignore the light and it goes away.
    But to test your SWG production- are you able to maintain your initial FC level (usually raised with bleach or other methods and then allowing the SWG to take over)?
    Can you collect a water sample immediately out of the return into your pool and test that- it *should* show a higher FC than the rest of the pool if the SWG is working.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by jonboy688 View Post
    Mine just had the same exact error yesterday and no chlorine added in 7 hours of run time.. raised the FC to 6 with bleach and did an OCLT and had 6fc at night and 6fc in the morning with SWG on all 7 hours... Called yesterday and will be calling them from home today.. they want me to send pictures and see if something inside the SWG is wired wrong..
    I called Discountsaltpool yesterday and they gave me the number for SGS, the company that makes it..
    I just checked and it is still creating chlorine this morning, so its been running 4 hours.. I have no idea what is happening...
    Apr 2015
    china grove,nc
    71
    Quote Originally Posted by cowboycasey View Post
    how long have you had yours? mine has been installed since may of this year(2015)
    Jul 2013
    Fletcher, OK
    3,353
    I bought mine in may also but just installed it and put it into use 3 weeks ago... hmmm, I wonder if there was a run of some RJ45's that were wonky...
    Apr 2015
    china grove,nc
    71
    just got off the phone with discountsaltpools and he wanted me to try to add salt to the system and see what happens, I will give this a shot and see what happens... even though I don't believe that will fix anything, as my level is already on the higher side
    Jul 2013
    Fletcher, OK
    3,353
    well the SJ have a salt level of 3000+ and the other SI and RJ have a salt level of 2800 to 4500..
    I am at 38/3900..
    Apr 2015
    china grove,nc
    71
    I double checked the salt level last night and got a reading of 3600, I added a bag of salt and see if it helps today, the unit seems to work until the end of the cycle with less then a hour left on the timer it throws the triangle alert light.... I have it coming on at 10am and going off at 8pm then have it come on from 2am to 4am at night
    Jul 2013
    Fletcher, OK
    3,353
    just got of the phone with SGS.. we went over all connections and found nothing that looks bad.. they are sending a new cell to see if that works or fixes it... we will see...
    Apr 2015
    china grove,nc
    71
    Well I thought my problem was gone but still seems to be present. I added two bags of salt and the level is 4000 now and still get the error light. Looks like I have it norrowed down to anything above 50% on the controller it will throw the error light. Which I am unsure it is has ever worked correctly as I have always had to have it on a high percentage to keep the cl level even before I was using a timer.
    My levels are all fine with the tft test
    Cya 70
    Ph 7.4
    Fc 8
    Cc 0
    Ta 80
    The unit is a 45k and my pool is 22000 gallon. I seen others with different systems only having to use 25-50% to keep the levels. I have to run mine for 12hours at 75% to keep around 8fc
    Jul 2013
    Fletcher, OK
    3,353
    I will try to test again tonight, I have 14000 gallons and have changed it to run 8 hours at 100% to keep it at 7 FC.. I was at 50% at 8 hours and it was dropping 1 fc a day... water is still balanced and clear...
    When I say keep it at 7 I test at 0600 in the morning and it is 7FC... at 9 at night it will be at 4 FC
    Apr 2015
    china grove,nc
    71
    well I sent mine in for repair today, said they think it is a controller problem and not a cell issue, sucks now I have to go buy bleach to keep the pool up for a week or two....
    Apr 2015
    china grove,nc
    71
    well turns out two of the boards were burnt up in the unit, and they are replacing them and sending it back this week
    Apr 2015
    china grove,nc
    71
    well got it back and now it works great, I think that it was having issues from the get go, as I always had to run long way to long compared to others, now I checked it after running it for 12 hours and my fc was 18
