Results 1 to 12 of 12
Thread: My plumbing diagram
    leeharvey's Avatar
    Aug 2015
    kennewick, wa.
    9
    My plumbing diagram
    Hi
    Been lurking on here for a couple weeks.
    We are in the process of putting in our Liner pool( 20x40' Roman) IG liner.
    This is what we came up with as far as pool plumbing & equipment pad plumbing.
    Where it shows ball valves, we are going with Jandy type.
    Also....the heater is going be the IG radiant heat.
    We live in Eastern Washington State, it gets HOT here....Sunny from March to October.....Hot May to Sept.
    Lemme kno your thoughts.
    Thx
    This website is the BEST...thank you very much!
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: My plumbing diagram
    With two skimmers have you thought about ditching the MD. It isn't really necessary:
    http://www.poolinspections.com/manua...out-drains.pdf
    Mark
    leeharvey's Avatar
    Aug 2015
    kennewick, wa.
    9
    Uhhh,
    I didn't realize that.....it came with the kit.
    mas985's Avatar
    Pleasanton, CA
    11,737
    It's up to you but knowing the issues people have with MDs, I would leave it out of my next pool, assuming there is a next pool.
    Mark
    leeharvey's Avatar
    Aug 2015
    kennewick, wa.
    9
    I agree!
    Its only a potential source of a leak at best....reading that study, worse!
    If we ever need to off load the h20 below the skimmer, I assume it can be done sticking a pool vac hose in the Skimmer and draining it that way.
    Thx!!!!!
    leeharvey's Avatar
    Aug 2015
    kennewick, wa.
    9
    Hi. This is Lee's wife, Charissa, sharing the profile Drains are now out of the picture! Thank you so much for the quick reply with such important information! Definitely love this site!
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Read my story in my sig on my FAKE MAIN DRAIN. My pool hasn't had one since I bought the house and pool back in 1998...and it's done just fine.
    I did, however, have an equalizer line put in on my skimmer during my recent pool remodel. This is simply an intake mounted on the wall of my pool about 2' down from the coping. I guess you could call it a 'wall' main drain.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jun 2015
    Wildomar, California
    423
    So without a MD, I would definitely add a pool cleaner.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Quote Originally Posted by OldPoolMan View Post
    Excellent point. Tap off one of your return lines with a tee and send it into booster pump and then send that line to the pool somewhere. My cleaner line is 1".
    ----Chris----
    mas985's Avatar
    Pleasanton, CA
    11,737
    Main drain does nothing for cleaning a pool. At most it cleans only the first few inches around the MD and nothing more.
    Mark
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    If you are gonna get a cleaner, I would recommend a robot.
    Do you think 3 returns as positioned will be enough? if the pool is large enough for 2 skimmers, I would think maybe one more return on the far side might be in order?
    Also just as a FYI, I dont have any main drains in my pool and have no problems with circulation or anything else.
    If the vac hose seals off in the skimmer 100 percent, that would work until you get to the returns. I suppose you could plug those though.
    Most folks just rent a submersible pump though.
    Quote Originally Posted by leeharvey View Post
    Thx!!!!!
    Divin Dave,
    leeharvey's Avatar
    Aug 2015
    kennewick, wa.
    9
    Yes Definitely!
    We have a shark vac xl I believe.
    Thanks for all the great replies!
    There are two returns opposite wall of the skimmers and one return on the same wall as the skimmers & we will have 2 step jets to help with circulation.
