Thread: Hayward Tiger Shark Problem
    Jun 2014
    Lumberton, TX
    1
    Evidently my Tiger Shark motor housing got compromised and moisture found its way in. I have the unit apart and had an electrical check done. All of the motors work as they are supposed to. The printed circuit board (pcb) is bad but have been unable to find a replacement. I believe the part number to be #RCX40106QC. I also understand that one of the Maytronics models as well as the Dirt Devil Rampage share the same parts and motor assembly.
    Does anyone know where I can find this part as I don't want to spend the money for a complete motor unit when all I need is the board. I would consider a new component or a used part in working order. Any help would be appreciated.
    38,547
    Re: Hayward Tiger Shark Problem
    Welcome to TFP!!!
    Sorry you have not gotten any responses, and I am no help. Bumping it up.
    Ellington, CT
    263
    Have you googled the part number (RCX40106QC.)? There are several hits which seem to be offering this part like Amazon.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    May 2015
    Chickasha, OK
    184
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
