- Jun 22, 2014
- 47,965
- Fiberglass
- CircuPool RJ-45 Plus
You can test pH about 30 minutes or so after adding acid with the pump running. Best to do it cautiously as to not overkill and go too low. Then start your SLAM. Remember, during the SLAM pH will not read properly (high) because of the high FC from bleach. So don't waste your pH reagents either. Wait until the FC settles back down below 10 to test pH. Good luck, and have a nice day.
