Results 1 to 8 of 8
Thread: Need help with Paramount In-Floor system
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I have a 6 port water valve from Paramount for my in-floor system. About a week ago it started become very loud as it went through it's different cycles. I also noticed that the pool isn't cleaning as well and dirt is settling in areas it never use to settle. The heads seem to pop up still. Any initial advice or thoughts before I open that thing up?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    38,290
    Re: Loud Paramount Water Valve
    Sorry you have not gotten any responses, and I am no help. Bumping it up.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Infloor Section stays up the whole time..
    Of my 6 stations, 2 are the same one (my stairs). They stay up the entire time my pool is on, including when other sections of the infloor are up. I opened up the valve module and I noticed one of the pistons does not seal with the module like it should when I push it in. It leaves a gap (see picture). Is this a failure of the module, meaning it needs to be replaced?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Should I adjust all my infloor heads to point in the same direction?
    I was taking my infloor heads out one by one today to make sure the holes were clear of debris, and then I got to wondering. Should I be setting all my heads in the pool to face the same way so that they follow the same rotation and move dirt accordingly? I think the way some of them are now may hinder the work of the head because they don't sync up just right.
    38,290
    Re: Need help with Paramount In-Floor system
    I merged all your related questions. Hopefully someone will be able to help.
    I am not sure if the orientation of the jets matter much. Might want to contact the manufacturer. Seems that many step up and help getting the systems dialed in.
    Aug 2015
    Hollywood, FL
    135
    I used to sync them up. But one day you'll have low flow for a few minutes and they get out of sync and it doesn't matter, or you'll step on one, or whatever. I have a different brand, but concept should be the same.
    When I have problems with the pool (or anything else), before figuring it out, I usually look online for the most common problems with the component, and look at those (or just fix them if it's cheap enough to fix, since they will likely fail soon anyway). For the floor system, problems that I've encountered:
    1. Garbage in the filter over the floor system would block the flow.
    2. Low flow: third party filters sometimes had lower flow than the OEM ones, low flow = heads not happy
    How old is the system? Mind has a "rebuild kit" that replaced a whole bunch of the parts. Apparently over time they just got worn and it stopped really working by zone. I did the rebuild kit, and it was like brand new. However, problems 1/2 cropped up and make the heads not work, cleaning the filter before the floor system and making sure enough flow in general and system is like new.
    If you get it working right, the floor systems are a thing of beauty.
    Pool, 11000 Gallon Gunite Pool, shallow ( < 5' deep ) including spa. Hayward 1750 Cartridge Filter. Pump is a single speed 2 HP Hayward Northstar. Polaris Caretaker 5 Zone Floor System. Pool ~ 8 years old. TF-100 Test Kit.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    My pool is about 5 years old. The company says that the module should last 5 to 8 years. I've done my best to clean out everything part of the system I could (backwash, baskets, heads). I'll wait to see what they say about the 1 piston not going back in but I bet that is my culprit
    May 2015
    Goodyear AZ
    14
    I had a similiar situation with my A&A 6 zone in floor cleaning system. Pulled the system apart and found one of the gears had snapped. Pool guy says he cant believe I got 7 years out of it because most don't last that long. I used the A&A retrofit kit and the thing runs like a top now. I never thought about aligning the heads though thats got me wondering if it would improve debris removal.
    The only issue I have is with the Hayward EcoStar VSP pump, the A&A system works great at PUMP SPD 1 2450RPM but when the pump switches to SPD 2 1553RPM the in floor system doesn't have enough pressure to work properly so the heads pop up only a little and pressure isn't enough to push anything across the pool floor.
    Im running SPD 1 from 0400-0800hrs then it switches to SPD 2 0800-1200.
    Anyone have a valve or solenoid that will shut the In Floor system off when VSP pump goes into SPD 2 or SPD 3?
    Shasta Pool 36X18 PebbleTec with Spa Hayward ProLogic PS8, AquaConnectWeb Automation with AquaPod, T-15 Cell, Hayward Sense & Dispense, Hayward 400NG Heater, Hayward SwimClear Cartridge Filter, Hayward EcoStar 3400 Pump, Hayward NorthStar 1.5HP Waterfall pump, A&A 8 head in floor cleaning system.
