Thread: Skimmer sock option
    Mar 2009
    Charlotte, NC
    539
    Skimmer sock option
    I saw that one can use a nylon stocking.
    I was shipped a DE filter of the wrong size & they didn't want it back.
    Is it cool to line my skimmer with it? Or better use the proper sock or the nylon?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Re: Skimmer sock option
    Knee high stockings are often good, look for ones with as fine a weave as possible. Keep in mind that you will often go through a couple of skimmer socks (or whatever substitute you are using) in a season, so you want to use something inexpensive.
