Thread: replacement panel
    Aug 2015
    South Mills, NC
    1
    replacement panel
    We have an 18x33x54" oval pool and need to replace one panel. Any advice? Thanks
    Jun 2012
    western NY
    1,559
    Re: replacement panel
    What kind of pool is this???? Most above ground pools I know of are one piece sides. I have seen some multi piece ones but they are far and few between. If you truly have one, you will need to drain the pool, disassemble the section that needs replacing and install the new piece. After that it is a matter of re-assembling and refilling.
    Got any pictures we can see?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
