Thread: Does pool temperature affect CYA readings?
    Aug 2015
    Jeffeson, MA
    64
    I read on one of my testing kits that the ideal temperature to get an accurate reading for CYA is between 70-80 degrees Fahrenheit. It said that if the temperature of the water is above that then it could artificially lower what the CYA levels are when you test and, in fact, your CYA levels could be higher than what the readings indicate. Is there any truth to that? If my outdoor pool is regularly over 85-90 degrees will that through off my readings?
    Thanks.
    Pool install 6/2015, 27,000 gal in-ground, vinyl, 16 mil clear solar cover
    Hayward Pro Series 300lb high-rate sand filter
    Hayward Tri-Star 2-speed Model# SP3215EE pump
    Hayward Goldline Aqua Plus Salt generator with Hayward T-cell-15 for up to 40,000 gal
    Aquacomfort electric heat pump model# ACT1100
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Does pool temperature affect CYA readings?
    Thats a good question.
    Im not sure if the higher water tems effect the CYA or if it does, by how much.
    I do know for sure though that at lower water temps, the accuracy of the test is definetly effected and the test sample should be taken inside until it comes to room temperature.
    No harm at all in doing that with warmer water either, if you are unsure. Or you could do 2 tests at the different temps, and compare them (which I have never done).
    test the water right out of the pool. Then pour it from the test tube back into the bottle and take the bottle inside for a while. Hour or so should probably do it. Then test again.
    Divin Dave,
    Mar 2007
    San Rafael, CA USA
    12,082
    This question has come up before and Taylor answered it by saying that the test reads properly except for low temperatures (like 50F). Room temperature is fine and it is not true that higher temperatures would change the reading, at least not for the Taylor CYA test.
    I think that some non-Taylor test kits may be more affected by temperature because those kits do not lower the pH when doing the test. The Taylor reagent has pH buffers that lower the pH to decrease melamine-cyanurate solubility. Otherwise, such solubility at room temperature is around 20 ppm and is temperature dependent. By forcing the pH low, the CYA is nearly all cyanuric acid, not cyanurate ion, so forces greater precipitation of mealmine-cyanurate.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Awesome! Good info to know.
    Quote Originally Posted by chem geek View Post
    Divin Dave,
    Aug 2015
    Jeffeson, MA
    64
    Great, thanks a lot!
