Results 1 to 7 of 7
Thread: Polaris Feed Hose Too Stiff???
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    My 380 is about 20 years old. I've tuned it up more than once w/ the Tune-Up Kit. It's been working better than ever this year, mostly when the heater's on. But, with the pool temp over 80, I'm not running the heater lately. 380 had a couple of leaking swivels, so I replaced 2 this year. Now, the hose seems much too stiff and actually seems to keep the 380 from settling back down to the bottom after the back-up valve cycle.
    All the hose floats seem to float, no leaks, wheels turn @ about 30 RPM, sweep hose sweeps, & thrust jet is set at 7 o'clock. Tried 11:00, 1:00, now back at 7 w/ no real difference at any setting.
    So, last resort, replace the whole hose??? It's the original hose. Does it really get too stiff over time to work effectively?
    P.S. Just learned of the "leader hose" (after all these years) and ordered one. I'll try that for ~$40 before replacing the whole length.
    Any thoughts??? Thanks!!!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Nov 2011
    Magnolia Texas
    80
    Re: Polaris Feed Hose Too Stiff???
    I replaced mine after 10 years. Comparing the old hose to the new one was like day and night. The new hose is much more flexible. My cleaner now covers the entire pool where before it did not.
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    Aug 2015
    San Jose, CA
    32
    I've got a similarly aged Polaris - not entirely sure of the number - and wondered if the hose needs replacing, too. It's got a leak or two and seems stiff. I see the Pool Store had them in stock, but didn't look at the prices. I also think it'd reach the whole pool if it were four feet longer... If a new one is lots more flexible, maybe it's time.
    18,000 gallon in-ground gunite pool, built circa 1965
    single speed pump and booster (old, probably mid-1990's), driving System 3 cartridge filter, old Polaris crawler, and rooftop solar.
    TF-100 test kit.
    Apr 2016
    Atlanta, GA
    10
    I was having problems with my Polaris 380 getting stuck in corners. It started when water temp fell to about 70. I tried everything I could think of then it occurred to me it would run just fine until the hose got completely straightened out- at which point it could not "re bend" the hose and would just stay stuck in the far corners. I just replaced the hose tonight ($105 on eBay) and it is amazing. I actually reduced pump speed because of the overall performance improvement. Water temp today is 57 and working great!
    Mar 2015
    New Orleans, LA
    81
    They get stiff when they get old and worst if old and cold.
    Apr 2016
    Atlanta, GA
    10
    Same experience here last year. I replaced the long hose (feed or lead? The d45) and had a huge difference for the better. I didn't realize the shorter hose was a different size so that didn't get replaced. When I opened 2w ago I noted Polaris kept spinning in circles and was comepletely because the shorter hose nearest the Polaris had a permabend to one side. It's on my shopping list but for now I just rotated it so the end is straight back and symmetric- works better but still needs replacement.
    Jun 2016
    Lake Dallas, Texas
    66
    Polaris 280 owner here. Same results....new feed hose made a world of difference in "Bruce's" performance. That and a rebuild kit, and he behaves like new.
    Something else, I wish I had learned about "sand and silt" bags a long time ago. They are amazing at catching the little stuff. Now we run the normal bag in the fall, and a sand/silt bag the rest of the year.
    Bryan
    33,000 Gallon In Ground Gunite/Plaster
    1.5 HP Pentair Wisperflow 2 speed pump and Pentair 60 DE filter
    3/4 HP Pentair Booster pump and Polaris 280 cleaner
    Cirrcupool SJ55 SWG. TF100 test kit
