Results 1 to 8 of 8
Thread: Do I need to add algicide weekly?
    Aug 2015
    Jeffeson, MA
    64
    If I keep all of my chlorine/CYA levels in check do you still need to add an algicide when first filling the pool and weekly like most of the labeling on the bottles say? I typically use the algicides that do not contain copper for my outdoor pool, but just wonder if they are actually needed if the other measures are kept in check. Thanks.
    Pool install 6/2015, 27,000 gal in-ground, vinyl, 16 mil clear solar cover
    Hayward Pro Series 300lb high-rate sand filter
    Hayward Tri-Star 2-speed Model# SP3215EE pump
    Hayward Goldline Aqua Plus Salt generator with Hayward T-cell-15 for up to 40,000 gal
    Aquacomfort electric heat pump model# ACT1100
    Apr 2010
    Central NJ
    227
    Re: Do I need to add algicide weekly?
    The only time some people here use algaecide is when they close the pool. I don't even use it then, I just tend to close it late and open early. If you don't keep you FC in check and you start to get CC > .5, we (the collective) recommend that you SLAM your pool.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Jun 2014
    15,186
    I agree ... don't waste your money on algaecides. Properly and consistently maintaining your FC/CYA levels (along w/ other items) will keep your water clear and algae-free all on its own. Save your money for pool toys.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    If you keep your FC/CyA relationship, then you do not need any algaecide. Chlorine kills algae and therefore IS algaecide.
    Divin Dave,
    Donldson's Avatar
    NW Ohio
    2,904
    Just to pile on, I have not put any algaecide in my pool in nearly 6 years.
    Of course the bottle says to use weekly. Just like the shampoo bottle tells me to wash my hair twice
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    No.
    May 2015
    Chickasha, OK
    184
    I haven't used any algaecide this summer, with the exception of the bottle of BackUp I threw in there right after my pool was opened, which turned my pool water into a St. Patrick's Day beer.
    That experience led me here to TFP, and I haven't needed anything other than liquid chlorine, muriatic acid, and a touch of baking soda.
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
    Aug 2015
    Jeffeson, MA
    64
    Great, thank you!
