Thread: Pebble tec pool
    Jul 2015
    Ceres Ca
    18
    Pebble tec pool
    Hello everyone I'm new to this forum I just got a pool installed it's ig2with salt system pentair pump I'm having a hard tome balancing my water free chlorine reads at 5 calcium hardness is at 150 CA is 20 TA is 110 Ph7.6 phosphates300..any suggestions on what to do first to fix this
    live in central valley pebble Tech 18920 gallons pentair pump sheer decent salt water IGP built June 2015
    38,514
    Re: Pebble tec pool
    Welcome to TFP!!!
    For us to be able to make any recommendations, we need reliable test results from one of the Recommended Test Kits. Pool store results, like you posted, have proven repeatedly to be inaccurate and unreliable.
    Have you discovered Pool School yet? Start with these (Note you will have to get out of Tapatalk):
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Water Balance for SWGs
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Pebble tec pool
    Welcome to TFP!
    We can definitely help you get your pool under control. +1 on getting a great test kit. I have used the TF100 from TFTestkits.net for over 3 years to maintain my pool.
    Jul 2015
    Ceres Ca
    18
    Re: Pebble tec pool
    Ok I will get out of tap talk...thx
    Jul 2015
    Ceres Ca
    18
    Re: Pebble tec pool
    The test was done by Leslies pool
    Jun 2015
    Rocklin Ca
    78
    Re: Pebble tec pool
    Having my pool 10 years, Finally after spending $250 in one month on my pool (Leslies would be around $400) at the local pool supply I found this group. So now I have total control of my pool, cleaner looking than ever and the cost is way down. So my advice is get one of the recommended test kits and learn the proper care from day one. I'll be honest I was skeptical of what I was reading in this forum after 10 years of pool store suggestion, well I'm sure happy I followed TFP advice. BTW Leslies is one place to stay away from.
    In ground 20,000gal - pebble-tec - salt, Intelliflo pump, Sta-Rite filter 450 sq ft ,Hayward 6060 booster pump, non functioning Aqua Rite SWCG, TF 100 test kit.
