Results 1 to 10 of 10
Thread: Can I close my pool without draining below the skimmer?
    We have a 27 foot above ground pool. We have tried every method of covering this pool in the winter, but I somehow always end up in a torrential downpour trying to pump the water off the top of the pool no matter what system we use to cover the pool. The last 4 years, we used the Duck Back pool cover that you inflate. That was the absolute best cover we have ever had, but it died a sad death this year. I just can't justify spending another $400 dollars to replace it if isn't going to last but 4 years. My questions are: We are considering not draining the pool below the skimmer this years and trying the Aquador skimmer cover. If we don't drain the pool below the skimmer, can we simply cover the pool making sure the cover rests on the top of the water and not use any balls or pillows? I realize that if we get a lot of rain or snow I'm going to have to pump off some water, but is it ok to leave small amounts? My husband obsesses with standing water on the pool. He is terrified that the walls of the pool are going to cave in. Does leaving the pool full lessen the chances of this happening?
    Hollye Abner
    27' above ground
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Can I close my pool without draining below the skimmer?
    Welcome,
    Sure it will help, but the less water on the cover the better, I must agree with him. Why not go with the pillows under the cover route?
    Essential Links:
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Where do you live? Does it freeze hard there?
    Kim
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    If you don't freeze, leaving water is fine. Just run the pump a little everyday. When we had the ag, we never winterized or drained below the skimmer.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jun 2012
    western NY
    1,559
    I use the aquadoor on my pool and never drain it down. All I do to winterize the plumbing is install the aquadoor cover and put a 1.5" plug in the return. (I obviously do drain all of the water from the pipes afterward).
    I use a simple tarp like cover that uses a cable to tighten it to the sides of the pool. I float a plastic 55 gallon drum under the cover to help keep it above the water. During the fall months, I syphon off the water that collects on the cover to help with the fall leaves. Once the trees stop dropping leaves, I don't worry bout the water on top. 15 years like this and no problems so far.
    Here is a mid winter shot of the pool...
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    l never drain and don't use a pillow. Never had a problem with just covering and wrenching down the cable around the outside. if its not frozen i always sphion off any water on the top.
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
    Quote Originally Posted by danpik View Post
    Do you tie down the drum in any way to keep it from moving around?
    Quote Originally Posted by kimkats View Post
    Kim
    We live in Southeast Missouri, 20 miles or so from the Arkansas line. We do have to deal with some snow and ice and freezing, but it usually doesn't last longer than a few days.
    Hollye Abner
    27' above ground
    wjr75's Avatar
    Jun 2013
    IL
    836
    The problem with not draining below skimmer in the Midwest is that eventually the water will get added on top of the cover over the winter. That will raise the water level that is in the pool under the cover up to rail level eventually. If it goes high enough one year to touch the rails it will eventually start to rust the rails because of it.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    Quote Originally Posted by wjr75 View Post
    I never drain my pool down
    Funny My cover does not let any water into the pool over the winter, I do have an Auto pump on top of the cover when its thawed
    I use a hurricane cover and no pillow
    I will actually loss a little water over the winter. But I use a Skimmer expandable plug and block the return, remove the hoses and pump
    1. Pocket Pool Cover - Easy Dome Pool Covers, LLC
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Jun 2012
    western NY
    1,559
    Quote Originally Posted by habner View Post
    I tied a rope around the waist of the drum , then two ropes, one to each side to keep it centered.
