Thread: Pulsar Auto chlorine pump
    Jul 2015
    griffin, ga
    29
    Anyone else using a Pulsar pump for auto chlorine input?
    I would like some input on setup, and if you had any problems with it being outdoors. Also does it seem to be reliable?
    I have mine setup to run on the same timer as the main filter pump. So, it is running about 6hr per day. I'm trying to dial it in to add about 1 gal of 8.25% bleach per day.
    For the first few days I'm going to try it at 30% for the amount and 40% for the time.
    I found that at 100,100 for both it will output about 1 pint in 3 mins.
    Attachment 41822Attachment 41823
    24ft Round AGP, built 5/10/15, 13500gal, 1hp Hayward pump, sand filter, hard piped, Pulsar Pulsatron Auto clorine pump. Intex auto cleaner robot. TF-100 XL with speed stir.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pulsar Auto chlorine pump
    Yes, many here are using injection pumps for feeding Liquid Chlorine. Most are using paristaltic pumps, but that can work too. You may have out-gassing issues with it however. If so, you might overcome it with a discharge vent back to the supply tank however.
    Essential Links:
