Results 1 to 7 of 7
Thread: Sand filter woes
    Jul 2015
    jefferson
    7
    Sand filter woes
    I recently bought a 2800gpm intex sand filter, the filter works awesome and the water is night and day compared when running the cartridge filter that came with the pool. The problem I've been having is with the sand. I bought sand from home depot, the quickrete brand. I kept finding sand at the bottom of my pool for some reason (water was still crystal clear.) I emptied the sand and washed the filter as well as everything inside, went to leslies pool and got some silica from them. I noticed after I loaded the sand and backwashed I was still getting a lot of sand coming through the backwash hose. I turned it to rinse and backwashed again, less sand but decided to run the outgoing line through the old cartridge filter to try and eliminate sand from coming in. I am now getting a little sand in the pool, not as much as before but it's still there and the water is still clear. This is driving me crazy, I read somewhere in these forums someone recommend HTH brand but I cannot find it anywhere!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    Re: Sand filter woes
    Did you backwash the sand thoroughly before you turned it to Filter the first time?
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    30,419
    This thread should interest you. It appears to me that there have been several reports over the years of Quikrete Pool Sand not being gyp to specs, This thread pretty much confirms that. My findings on how not all sand is created equal
    Jul 2015
    jefferson
    7
    I read that post earlier, I cannot find the HTH sand anywhere and wanted to see what other sand people have had good luck with. I also saw someone was in the New Orleans area and was hoping they could point me in the right direction.
    Quote Originally Posted by jeffchap View Post
    I backwashed enough to lose 2-3 inches from my pool, I figured that was enough, switched to rinse and backwashed another 45 seconds or so.
    30,419
    Sort of hi-jacking here (but I think this may be related to your issue) I have emailed Quikrete and invited them to respond to these reports.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by 504plumber View Post
    I found my HTH sand at Ace Hardware
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Apr 2014
    FOUR cORNERS
    111
    I had this happen to me also when we first received the sand filter, I watched a couple of you tube videos, I left out a step, after vacuuming I would backwash and switch to filter,I would get sand and a lot of it. **Now I vaccuum , backwash till sight glass is clear, turn pump off, move the valve to rinse position, let run for about minute, this settles the sand,turn off pump, move valve lever to filter, all good. hope this helps
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
