Results 1 to 12 of 12
Thread: How long before we can swim?
    May 2015
    Land O Lakes, FL
    527
    We are scheduling the pool build and want to be able to swim by Mar 1st.
    So once the build is finished and water goes in, is there a waiting period while water is stabilized, everything settles in....
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: How long before we can swim?
    Unless your builder does a hot (acid) start, you can swim that day. You could easily adjust pH if needed, Chlorine, and swim away. Some builders and info tell you plaster needs cure time before swimming, but I'm not in that camp. Of course if it's vinyl, or FG, then you don't even have that worry.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I'm not in that camp either. We were in the pool before it finished filling and had a big pool party the first weekend.
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    We were told 5-7 days. I'm bummed!
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Ours was a hot start so about a week for pH to rise back up. During this time I was brushing to expose some of the quartz aggregate. Wouldn't have wanted to swim too early aside from low pH because of all the plaster dust.
    So type of plaster finish and method of startup are key.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2015
    Land O Lakes, FL
    527
    Ok, thanks, I had read that it would be 30 days.....
    Matt
    DFW, TX
    24,485
    Our pebble sheen was acid washed before fill so there was minimal plaster dust. PB even said the initial daily brushing was optional.
    Jun 2011
    Carlsbad, NM
    172
    You can't even run a cleaner for two weeks as it will leave marks. My friends decided to swim the first day against the pool builders instruction. Now they have permanent marks in the shallow end from feet. Looks like a stain from the surface. With my plaster, I had dust for at least two weeks, and it will stick to the fresh plaster if you walk on it.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Our PB said jump right in. We did, had a party first weekend. Was in the pool less than an hour after the fill completed! Was told not to use Polaris for a couple of weeks. And of course wait 30 days before salt was added.
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    May 2015
    Land O Lakes, FL
    527
    So it sounds like there is some disagreement on this. . What are the reasons that swimming should be delayed for weeks to a month?
    Matt
    wjr75's Avatar
    Jun 2013
    IL
    836
    Depends on your finish. We had ours redone with pebble sheen and were swimming a few days after the initial balancing. We waited a few weeks before using the polaris 280. Regular plaster I believe is softer and needs more cautions.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    I think the most common ones are mentioned above and a few others:
    pH out of range
    Excessive plaster dust
    Susceptibility of plaster to damage
    PB is holding the warranty card
    It's not swim season yet
    Lots of reasons to swim quickly too.
