Thread: whats everyones thought
    Is it possable to get that much sand on the bottom or could it be mustard algae. ....not my pool !!!!
    24' x 52" VINYL AG 15,200 GAL.
    HAYWARD POWER FLOW LX 1.5 HP
    HAYWARD SAND FILTER
    Taylor K-2006
    Jun 2014
    15,059
    Re: whats everyones thought
    Mustard algae is a yellow green color and grows on the walls and floor mostly on the shady side of the pool. Dust/pollen will keep re-appearing, but will never accumulate on the walls of the pool. If you do shock the pool, mustard algae will mostly disappear as long as you are at shock level and brushing occasionally. Dust will continue appearing at the same rate when you are at shock level.
    By the looks of it, I kind of doubt it is MA simply by it's location and being in the sun.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Looks like plain old algae to me.
    Donldson's Avatar
    NW Ohio
    2,892
    Add another vote for plain old green algae. Some of it appears to be dead but there definitely seems to be a green tint to it.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
