Thread: Hi all..
    Aug 2015
    PETALUMA
    2
    Hi all..
    First pool... trying to learn the ropes. All going good except for my wife's green hair...
    In ground fiberglass pool, 12' x 25', 10000 gal., with 4 laminar deck jets, a spa, a 460 sq ft cartridge filter and a variable speed pump. Also has a 250 btu gas heater
    Jun 2014
    14,981
    Re: Hi all..
    Uh oh... green hair could mean copper in the water. Water form a well or have you used algaecides in the past? Well, in any case, we're happy to have you with us. Let us know if you have any questions. Always glad to help.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: Hi all..
    Hi Matt,
    Welcome to TFP!
    The green hair is caused by the copper in the algaecide you've been using. Help the wife shampoo her hair with catchup, and it will remove the ionized copper from it. It might to 2 go rounds to get it all, but it will.
    If you would like to learn to maintain your pool without using algaecides and phoshpate removers, then clicking on the pool school button is the best place to start.
    Enjoy
    Divin Dave,
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hi all..
    Welcome to the forum!
    Yep...the green hair definitely sound like copper.
    These 3 articles will help get you started on properly managing your pool:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    Donldson's Avatar
    NW Ohio
    2,881
    Re: Hi all..
    Welcome to TFP Matt!
    Just want to put this link here to your friend helping you with your pool so everyone knows what has been going on: Petaluma pool needs water balanced.
    Looks like the copper either came from previously used algaecides or possibly stripped from the heater when the pH crashed.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
