Thread: How inaccurate is pool math when you add borates?
    Mar 2015
    Harvey, LA
    300
    From the poolmath site:
    Note: pH calculations are not exact. These numbers are only suggestive of the relative magnitude of the pH change you can expect. Small changes, +-0.4, with pH between 7.2-7.8, TA around 80-120, and Borate near zero will be approximately correct. The further you go from those ranges the less these pH changes will correspond to reality.
    How inaccurate will the numbers be when you have borates at 50? I'm about to have to add some acid to lower the pH since my borate addition, and I'm assuming it will take more acid to do it, but I am unsure how much more...or is that just for the chemical calculation and the top portion of poolmath is going to be more correct?
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    JoyfulNoise's Avatar
    May 2015
    13,170
    Re: How inaccurate is pool math when you add borates?
    Doesn't that warning just apply to the "Effects of Adding Chemicals" section? I think it does.
    Matt
    Sep 2014
    Bakersfield, CA
    155
    If you tell PoolMath you have 50 ppm borates it will significantly increase the amount of acid needed to make a given pH change.
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
    Mar 2007
    San Rafael, CA USA
    12,082
    PoolMath has calculations in the upper section (such as how much acid to add to lower pH by the requested amount) that account for Borates if they are in the normal 0 to 50 ppm range. The "Effects of adding chemicals" section does NOT account for borates or anything else -- it uses assumed values of CYA, TA, and Borates for its pH calculations.
    Mar 2015
    Harvey, LA
    300
    Cool, thanks!
