Thread: Above Ground Pool Liner / Pool Wall Lean
    Aug 2015
    winthrop, ma
    2
    Hello Everyone. First post - two issues/ questions
    We recently installed a 12x18 AGP (oval). Has the buttress support system, so there is a metal brace in the center of the side walls on both sides under the upright support to hold the weight. This brace creates almost a slight inward curve on both sides in the center (normal I believe).
    Question 1 - I noticed a slight lean (outward) on both sides of the pool on the long side, on one side of the metal support. If I take my level, it appears to be 3/4 of an inch on one side of the metal brace (only one panel) and the other side of pool same issue but less of a lean (about 1/4 inch). Remaining panels appear to be pretty straight. Any level issues less than 1/4 inch. Is this a problem? My concern is if my pool collapses, my neighbors would be flooded cause I'm up on a pretty steep hill.
    Question 2 - I noticed inside the pool, where the wall meets the ground all around, the liner is pretty smooth and nice and rounded on the edge floor. Except in one spot, about 5 feet long, it seems like there is something under the liner (maybe sand), however it almost creates a "step" on the bottom. About 2-3 inches up and 2-3 inches out? Making a 90 degree lip almost on the bottom. I'm worried this could rip the liner. Is this a major problem?
    Thanks for the help!
    Aug 2015
    winthrop, ma
    2
    Re: Above Ground Pool Liner / Pool Wall Lean
    I wanted to attach a picture of the bump on the bottom of the pool against the wall. Picture is from above, looking down to pool floor.
    12x18 Oval Above Ground Pool 5,500 gallons
    DE Filter w/ Deck around half of pool
    North East Coast, US
    Casey's Avatar
    SW PA
    10,461
    Cant really see what the issue is in the pic because the water is so clear. Night time pics are great for showing off imperfections. The key is to having a good under water light.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,556
    I have my 16' round pool inside a 16'x16' wooden framed sandbox, and the liner presses onto the frame in a couple of spots just as you describe. It's been up for 2 years now, with no apparent damage. And it's just an Intex, so I'm guessing it's not the highest quality liner available.
    I have a 9 y/o son with rowdy friends and cousins, so it gets plenty of use/abuse. My opinion is that you'll be fine.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Aug 2013
    south east Arizona
    200
    Is the bump hard or could it be a piece of foam pool cove that got folded over or not stuck to the bottom of the wall correctly? If it is a sand cove I would assume no big deal if the area where the bump meets the wall is at least above the ground a bit, watch for leaks there and repair as needed.
    Not sure what to say if it is a foam cove that is not in the right place, hopefully someone will have an idea.
    Take some more pix of the outside and also where your other problem area is, or are they in the same place?
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
