Results 1 to 8 of 8
Thread: Coping with best heat absorption tolerance
    Jun 2015
    Tarzana
    2
    Looking to build our pool and sifting through the many material options. Is there a recommended coping material that works well with salt system that does not absorb a lot of heat?
    We are in Southern California and walking barefoot on super-hot coping is not ideal.
    Thanks in advance!
    - Ran
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Coping with best heat absorption tolerance
    Concrete. Our concrete deck is noticeably cooler than every rock surface around our pool. We can stand in the concrete deck most of the time when we can't stand on the flagstone, sandstone or retaining wall rocks.
    Mar 2007
    San Rafael, CA USA
    12,082
    Even with concrete, it depends on its thickness. We have thick concrete coping 3.5" thick and these blocks get very hot. Our troweled concrete that is made to look like flagstone is not hot because it is much thinner, but I don't know it's exact thickness. The difference is that with thinner concrete the cooling down from the ground under the concrete reduces its temperature more. With thick concrete, the underside of the concrete may be cooler but the surface exposed to the sun remains hotter. Basically the thicker concrete is like having more insulation between the top and bottom sides of the concrete.
    Jun 2015
    Florida
    74
    We don't have coping. Our decking just overhangs edge of pool. It's travertine and I've never felt anything cooler.
    Aug 2014
    NJ
    435
    Quote Originally Posted by JupPool View Post
    Travertine and marble coping are very cool to the feet
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Jun 2015
    Tarzana
    2
    Thank you all! This is all great advice
    Jul 2014
    New England - MA
    310
    My Techo bloc Piedmonte coping seems much cooler than many other surfaces I tested. It will withstand saltwater, our pool is saltwater.
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    LongDuck's Avatar
    Aug 2015
    Phoenix, AZ
    39
    We went with very light colored travertine with a tumbled edge and it's cool enough to stand on in mid day heat here in Phx. That's saying something. I have a buddy with brick paver deck and it is like walking on lava in comparison, due to the darker brick color and texture.
    We wanted o avoid blinding reflection, but it's a trade off to get a deck you can walk with bare feet and not get burned in my neck of the desert.
    July2015 New - 12,900gal IG Clorine Pool: Free Form Shot/PebbleSheen, Ceramic Waterline/Travertine Coping/Deck, Paramount PV3 In-Floor, Pentair 3050VS Intelliflo Variable (3000rpm High/1000rpm Low), Pentair Clean & Clear 420 Cartridge, Venturi Skimmer, MDX/SDX Drain, Paralevel, Rock Waterfall +3/4" Aireator, Intellibrite 5G LED, EasyTouch4, and Tab Floater.
