Thread: Jandy PDA problem
    Aug 2015
    Riverside
    6
    Jandy PDA problem
    OK, my first post to this so i hope i'm doing it correctly. I have a Jandy PDA system on the pool that is controlled by the handheld remote. I do not have an aqualink control inside the house, but i can control everything fine with the remote, however, this is the crazy part. When the sun is at it's highest point and it's hot outside i loose all control with the handheld, until the sun gets lower...go figure. I have tried moving the antenna to a different location and that did not help. It only does this in the summer, not in the winter....ie, different sun location i guess. Has anyone else had this problem and what did you do to solve it? Thanks for the help
    Aug 2015
    Riverside
    6
    Re: Jandy PDA problem
    Wow. nobody else has ever had this problem!!!
    jv92red's Avatar
    Mar 2013
    SoCal
    117
    Welcome to TFP! You have to give your question some time for people to see if they can help. Not everyone on here runs that system but mine is similar. While I don't have the PDA system specifically, I have the Jandy Z4 system with a PDA like yours that communicates to a J-box like you have and I have not experienced any thing like this. But my J-Box only gets afternoon sun exposure so perhaps not as long a time to cook the components like yours it seems. There is a small PCB board in there that sounds like one of the components is getting hot and temporarily quitting on you. Depending on the install hopefully there is enough extra line to experiment and move around the J-box to where you can find it some shade and still have it connect to the power center.
    15'x35' IG 16,500 gallons w/attached raised 18" spa continuous coping w/underneath spill and ledger stone wrapped, NPT mini pebble aqua blue w/2x pigment & abalone shell finish, 2"x24" travertine coping, 3x Jandy Color LED lights (2 in pool), Jandy Flo Pro 2HP VS pump, Jandy LXI (low NOx) 400K BTU heater, Jandy CL460 cartridge filter, Jandy AquaPure Ei SWG, Jandy Z4 automation with iAqualink and remote poolside PDA, 1,300 sqft Belgard Catalina paver deck with drainage, fire pit that matches the spa with travertine coping and wrapped in ledger stone, Elitewood insulated patio cover, Vinyl gates, back vinyl fence coming soon...
    TF-100
    Aug 2015
    Riverside
    6
    Well, Thank you for your response. I did think i allowed time, but, thought maybe I had stumped the panel. That being said I do have enough extra cable to try other areas and hopefully that will solve the problem. I had already moved it twice and it didn't seem to help, but I will try a couple more areas. Again, thanks for the comeback
    Aug 2015
    Riverside
    6
    OK, So by moving the antenna to a place where it can not be seen by the equipment worked. It was not overheating as i suspected it was. I downloaded the instruction manual and it said the antenna had to be at least 10 feet from a blower and all the equipment is in an enclosed block wall area that is enclosed on three sides, so I moved it outside the wall, so it would not get interference from the spa blower. The funny thing is Originally I moved it further away, but it still had a straight shot to the equipment, so it was still interfering. It had to be out of site from the other equipment. Anyway problem solved and back to enjoying the pool
