Thread: Pool basketball hoop pole... where to get a replacement?
    jtb33's Avatar
    Jul 2012
    Phoenix, AZ
    27
    We have an in-ground pool in AZ with a deck hole for a pool-side basketball hoop. The hoop itself and backboard are fine, but since we have a salt pool, the bottom of the pole that the backboard attaches to has corroded, so I need to replace it. For the life of me, I cannot find just the pole. Any help or suggestions?
    My pool:
    89' perimeter, 15,150 gallons, depth: 3x5x4
    Hayward C5025 w/Hayward 2HP tri-star pump, 2" PVC piping
    Goldline Pro Logic P4 w/salt system and Aqua Pod wireless remote
    Magnasweep in-floor cleaning system
    Pebbletec Caribbean blue
    Grotto w/waterfall and rock slide
    Play-step w/water feature
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool basketball hoop pole... where to get a replacement?
    I'd go with a stainless piece to replace it with. Check with some fabrication/welding shops, or steel suppliers.
    Essential Links:
    Jan 2012
    'burbs of Augusta, Georgia
    7,301
    Can you fabricate something using PVC?
    jtb33's Avatar
    Jul 2012
    Phoenix, AZ
    27
    Quote Originally Posted by Patrick_B View Post
    I wish I could find such a place around here that had something that would work...
    Quote Originally Posted by YippeeSkippy View Post
    Not sure PVC would be strong enough to hold the backboard and rim up (it's a full breakaway one with a very heavy backboard).
    My pool:
