Thread: Algae in shade; almost got it, but...
    Aug 2015
    Greenwood, MO
    1
    Question Algae in shade; almost got it, but...
    After research, I realize now that by shocking the pool (an above-ground SummerEscapes 18x48 with the standard 1500gph filter) isn't quite going to kill the algae that has suddenly emerged in our pool's shady side. I have a phosphate remover, an algaeside and a flocculant on order. However, I'm concerned how to vacuum it all up once it's dead. I have a Skooba Pool Vacuum that *usually* does a fine job, but with the algae, it just seems to "slime" the debris bag, making it useless. Any ideas??
    Jun 2014
    15,249
    Re: Algae in shade; almost got it, but...
    Hello and welcome! Well, if I may give you the typical TFP response - cancel the order on phosphate remover, algaecides, and flocculent. Use our SLAM instructions at Pool School - SLAM - Shock Level And Maintain to properly rid your pool of algae. There simply is nothing better. Remember though, to do this you must have the proper test kit (TF-100 or Taylor K-2006) from TFTestkits.net.
    Let us know if you have any question about the SLAM page. Welcome!
    AprilsZoo's Avatar
    Jul 2013
    100
    BTW, once you have killed the algae by SLAMming it, then it will be much easier to vacuum it up. Live algae slimes the bag... dead algae, not so much.
    🌵 April 🌸
    Some of my posts may be long... but they're *always* worth it! 🙃
    👙 Intex UltraFrame 21' x 52" {~10,000 gal.} 🐠 Krystal Klear 16" Sand Filter 🐳 Pentair Intelliflo 1.5 hp Variable Speed Pump🐬 Borates @ ~50 ppm 🐚 Taylor K-2006 test kit & SpeedStir🌀
    30,432
    Welcome to the forum.
    I do not understand the premise. adequate chlorine kills algae whether it is on the shady side or not.
    If you SLAM your pool, the algae will be gone. If you perform the SLAM half-heartedly, it will not. read "SLAM" in Pool School
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Also brushing is important to expose algae to the chlorine.
