Thread: where/how to add chemicals??
    Jul 2015
    Port Neches, TX
    53
    Just set up pool this weekend, last night realized what a pain the taller walls are!! Our old pool was only 36" tall so I was able to walk completely around the perimeter to add in chemicals diluted with pool water in a bucket! Between tripping over the pavers for the legs, and me being a short 5'2" it killed me! I actually had to stand on the ladder and on the other side, a cinder block!
    Ideas on how to dilute/add chemicals? Have a skimmer but was afraid putting the chemicals in there would filter directly out, or corrode the guts of the pump! Have CYA tied in a sock tied to the ladder, and squeeze it a few times a day to help dissolve. Usually put bleach in a bucket full of pool water and walk around adding small amounts to the pool. Same thing with baking soda....
    Our inlet isn't covered with water because we are only partially filling because of our son's height....So it actually hits the surface of the water in the middle of pool so I can just dump in front of inlet eyeball.
    Any ideas?
    22' x 52" Intex UltraFrame ABG, 10,500 gallons
    using TF-100 test kit
    Krystal Klear 633T Filter Type B pump - 2,500 GPH
    Intex wall-mount surface skimmer
    Jun 2012
    MA
    347
    Re: where/how to add chemicals??
    I don't dilute bleach when I add it to the pool. I pour it in even with the pump off, I usually rock the pool wall back and forth to mix up the pool a little.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I pour mine in front of the outlet, that I usually have pointing down, and to the side.
    Jun 2014
    15,189
    Our typical response is to slowly add chemicals near your return jet(s). You're doing fine with the stabilizer in the sock. Allow the pump to circulate water for about 30 minutes after adding chemicals. Remember never to add bleach and acid at the same time. Typically there is no need to dilute chemicals, but if you chose to do so in advance, it should be fine. Normally we don't advise adding chemicals directly to the skimmer.
    Hope this helps.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    This page shows what chemicals are, what they do and how to add them to your pool. Pool School - Recommended Pool Chemicals
    Jul 2015
    Port Neches, TX
    53
    Texas splash, how long do you wait between muriatic acid and bleach?? I had to add both last night and did the diluted acid and about 10 minutes after that the diluted bleach. Haven't tested since then so don't know if I threw off anything.
    Poolldv, thanks for the link! I printed it out for future reference, lol!
