Results 1 to 10 of 10
Thread: Is this it?
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    Is this it?
    It's 30 minutes to sundown, pool is like glass other than the slght roll from my last dip. Water is TFP perfect and 83 degrees. Outdoor thermometers indicate that it's still over 90. Barley pop is cold and within reach. Margaritaville radio rolls at a reasonable volume out of the boom box. Cats relax in the cool recently watered lawn. My trunks are still damp but could probably use a refill. The pool light is on but not yet taking any effect other than playing the role of cyclops at the far end of the pool. Anything beyond 'right now' is far from my mind.
    Yep, this is it. This is one of the moments that I envisioned when I crossed that 't' when signing that contract last June. Ahhhhh.........
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
    38,262
    Re: Is this it?
    We just came in from a pool party ourselves ... its a rough life
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Is this it?
    oh yeahhhhhhhhhh.....<deep contented sigh>
    Mod Squad pooldv's Avatar
    DFW, TX
    24,471
    Re: Is this it?
    Nice!!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,975
    Re: Is this it?
    I'm afraid so. Pool maintenance can get pretty boring.
    Take a water sample down to the pool store and see what you need to get things fixed up. That will give you something to do for the next few weeks.
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    Re: Is this it?
    Well worth the investment!
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    Re: Is this it?
    Sounds heavenly!
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    Jul 2012
    Central Texas
    436
    Re: Is this it?
    We didn't go in tonight, but we went to Freddy's, got some ice cream for dessert after grilled shrimp skewers and sat on the edge of the pool after dark talking about our day and watching the kids run around like fools barking their cute little corgi heads off. Sometimes you don't even need to get in the pool to feel its relaxation.
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    May 2015
    Chickasha, OK
    184
    Re: Is this it?
    I've thought about doing that just for grins...
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,215
    Re: Is this it?
    Even reading your description makes me feel relaxed! The power of pools....
    Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
