Thread: Daily Tests
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    Daily Tests
    I realize that this is a total newbie question, but I'm really confused.
    If my daily Chlorine OT tests only for TC, how do I know how much bleach to add if the amount is based on FC? Do I need to the DPD test every day to figure out how much FC I have?
    13 K gallons, in ground, rectangle, 14 x 30 Vinyl, single main drain, Sand filter, Hayward Tablet Chlorinator, Pentair Pump
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Daily Tests
    The OTO test kit is handy for a quick "look-see" to confirm that yes, there is chlorine there! (or conversely no, there isn't any chlorine in there!). Since it only goes up to 5ppm it isn't terribly useful to me.
    I just run a quick pH test and a DPD drop test (with CC test) for my daily or every other day tests.
    As to how much bleach to add I know that whatever my FC is I can add 17 ounces of bleach and it will raise my FC by 1ppm.
    For your sized pool 19 ounces of 8.25 % should raise it 1ppm. Makes for a fast way to bump up the FC by knowing that.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: Daily Tests
    If you have the fas-dpd test, use it. Accuracy counts!
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    Re: Daily Tests
    Okay, that's what I thought, but I just wanted to be sure I wasn't misunderstanding my TF-100 instructions.
    Thank you.
