Thread: How hard to replace this piece of pump piping?
    Nov 2014
    Palm Desert, CA
    99
    There is a hairline crack on the top black piece of piping (where the wires are coming out). We have wrapped with yellow plumbers tape and it held for awhile but is back to leaking. We need to replace that entire middle section of pipe. How hard is this to do? Just disconnect the wires, disconnect the pipe and replace with a new piece? Any idea what this piece is called so I can try to find it online? Thank you!
    Correction - It is just the gray (not black) top piece that has the crack.
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    30,426
    Re: How hard to replace this piece of pump piping?
    That is a sensor but you do not show where it is going??? Replace the pipe from the filter to the pump....pretty easy.
    Nov 2014
    Palm Desert, CA
    99
    The wire from the sensor is going to the SWG. I double checked and the leak is coming from a hairline crack in the white piping piece just below the gray cap/sensor. Do you know a good place to purchase this piping online or just go down to Leslies? Any tips for installation? Thank you!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Lowes or Home Depot or Ace should have what you need.
    You have to
    1. kill the pump by shutting it off at the breaker
    2. Unscrew that sensor and set it aside.
    3. saw the pipe off as far away from the filter and as close as you can to the Tee with the sensor in it.
    4. possibly saw it off again somewhere so you can unscrew it from the pump
    5. take the pieces to the store and match the sizes. It looks like maybe you can replace two street elbows and two couplings with a standard elbow. A union will simplify reassembly. Just look for a knowledgeable clerk. That may be the hardest part of it.
    Feb 2015
    Davis, CA
    97
    I am confused (nothing new). Are you saying the the white PVC fitting is cracked or is sensor cracked?
    Assuming that you're talking about the PVC fitting, you are looking for the following schedule 60 PVC fitting listed below. You may need to replace the 2" with the correct size (either 1-1/4", 1-1/2" or even bigger). The threaded part will remain 1/2" threaded regardless of what size pipe you need. I have not had success finding these Tee's at Home Depot, but my local Ace Hardware carries them.
    2" (slip) x 2" (slip) x 1/2" (threaded) Tee.
    Amazon.com : Hayward GLX-FLO-T Flow Switch Tee Replacement for Hayward Salt Chlorine Generators : Swimming Pool And Spa Supplies : Patio, Lawn Garden . You can get it cheaper at your Ace Hardware.
    If you're talking about the sensor, then you need a flow sensor. Just do a Google search for "Hayward Flow Sensor". Amazon.com : Hayward GLX-FLO-RP 15-Feet Cable Flow Switch Assembly without Tee Replacement Kit for Hayward Salt Chlorine Generators : Swimming Pool And Spa Supplies : Patio, Lawn Garden
    Can you give us a zoom out picture of your plumbing and tell us exactly what you are trying to replace?
    Minh
    Pool Remodeled June 2015. 18K Gallon IG kidney shaped. Pebble Tec (Tahoe Blue) finish. Jandy ePump 2HP. Hayward SwimClear C2025 filter. Hayward SWG. Jandy iAqualink RS6 automation. 6 Deck Jets. Pool Remodel Link Future: Acid automation. Chlorine automation for winter. Solar panels.
