Results 1 to 8 of 8
Thread: What is this connection?
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    Hello,
    we just renovated our pool that came with the house. Trying to get the pool piping fixed and found this weird looking connection ( the black color rubber tube)and can't figure out what it is and should I replace it and with what?
    Thanks
    24k IG vinyl , new (not any more)pool, new ( not any more) water Hayward super pump and sand filter.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: What is this connection?
    That is a flexible rubber coupling. It is OK to use that with PVC.
    30,421
    Looks like that is on the pressure side of your system and I would remove it. It is a cheap, cheap connection and will likely continue to swell and perhaps leak.
    DFW, TX
    24,497
    Oh, yep, not on pressure side.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Replace it with a union. The outer ring unscrews. The two ends glue to the existing plumbing. If there's any flex at all in the pipes, it shouldn't be any big deal to do it in place.
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    Thank you.. I don't know wht is the pressure side but it's right on top of the motor..connecting to the filter.. Also I am changing the motor so thinking to change the connections...
    thanks again for the prompt reply..
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    The pressure side is everything after the pump.
    The suction side is everything in front of the pump.
    Divin Dave,
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    Quote Originally Posted by Divin Dave View Post
    thanks..that's a great piece of information!!
