Thread: grounding inside wet quick niche
    Aug 2015
    macomb twp
    30
    Do i have to put the bonding compound just on the wire connection part or the entire grounding connector so no metal is showing?
    Corleone's Avatar
    Aug 2014
    Menifee/CA
    194
    Re: grounding inside wet quick niche
    You want to cover all the metal to prevent corrosion.
    13K Gallon IG Pool/Spa -- First time pool owners -- Completed in 2015 Caribbean Blue Pebble Tec Pentair 4000 Series 47 sq. ft. D.E. Filter Pentair IntelliFlo Variable Speed Pump Pentair SWG Jandy LXi Heater 400,000 BTU S.R. Smith Typhoon Slide Pentair LED 12v Lights Dolphin Nautilus Robotic Cleaner TF-100 Test Kit
    Our Build Thread
    30,400
    +1 what corleone said.
