Results 1 to 9 of 9
Thread: Looking for a go - no go on this run capacitor
    comawhite12's Avatar
    Jun 2010
    South Texas
    56
    Hey all,
    Well after replacing the shaft bearings on my sand pump a few weeks ago, it started getting crappy loud again (but different sound) until it shut off on me today 30 mins into a cycle. After popping the cover off again and checking shaft is freely rotating (it is) I tried to start it and the famous BUZZZZZZZZ of a bad cap presented.
    I have found this one Frigidaire Electric Motor Run Capacitors CBB65 35 uf 250VAC | eBay and am wondering if this will work. I think it should, but would like a second opinion.
    Thanks
    15' Intex frame set
    4600 Gallon
    2650gph Intex Sand Filter
    NightLighter 35W
    Red Neck fountain
    Re: Looking for a go - no go on this run capacitor
    What are the specs on your old capacitor?
    Support the site
    Jun 2010
    South Texas
    56
    Identical 35uF 250vAC 50/60 hz. The dimensions seem right as well, so it should be fine.
    Just a little skittish because I am no electrician.
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
    Looks good.
    Support the site
    Jun 2010
    South Texas
    56
    Thanks for the reassurance!
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
    Mar 2015
    Sugar Land , TX
    424
    Yeh I have had to replace run / start capacitors on my a/c more than a few times. Just swap the wires ( take a picture first ) and power back up. Make sure you discharge the old cap first !
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Jun 2010
    South Texas
    56
    OK, Update time.
    I just got the new cap in today, and I installed it on the motor. Got everything put back together and it is doing the same thing. Hella loud hum and wont spin. I checked the shaft was free again, and it is fine so I am out of ideas.
    Any help? My water is steadily heading south
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
    Can you post a picture of the motor and the motor label?
    Support the site
    Jun 2010
    South Texas
    56
    It is the Intex 2650gph pump. I have come to the determination the winding is toast. The capacitor is doing its job, but the motor is smoked.
    Anybody have any insight on this pump Amazon.com : Blue Wave NE6171B Maxi Replacement Pump for Above Ground Pools, 1.5 HP : Swimming Pool Water Pumps : Patio, Lawn Garden ?
    I am looking to swapping the motor out with this and using the existing Intex sand filter.
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
