Results 1 to 7 of 7
Thread: Leak in Cell Body---anyone seen anything like this before
    Mar 2015
    Harvey, LA
    300
    I inspected my cell and cleaned it this morning, and I found this leak in the body of it. I think this has been here since I installed it a month ago, as my equipment pad has been wetter since installing my swg but never noticed where it was coming from...my flow sensor leaks too, and thought that was the only place where my leak was coming from
    Swg leak in body - YouTube
    Anybody seen similar from circupool?
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Leak in Cell Body---anyone seen anything like this before
    Question.
    When your pump is off, is the SWG still powered up?
    The reason I ask, is because if the cell is still powered and trying to make chlorine while pump is off, then a build up of hydrogen gas inside the cell can take place. If the build up becomes too much, it can crack the cell, or worse, make it explode.
    It does not happen often to my knowledge, but has been known to.
    Divin Dave,
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by Divin Dave View Post
    Question.
    We're the instances you heard of caused by an ignition of the hydrogen, or actual pressure inside the cell? You'd almost have to be trying to blow it up I'd think. Like closing valves and such. Just curious. The OP's cell is interesting since it look like just a pinhole. Have you contacted the manufacturer or rep yet? I assume you got it from discountsaltpool. They seem like good people to me. I bought my SI60+ a couple months ago.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Mar 2015
    Harvey, LA
    300
    My cell is on the same relay as the pump, so it does not stay on after the pump is off. I did send an email to DSP this morning since they're closed. I have no doubt they'll make it right, especially since it is so new. I was more curious if this is something that has happened to others or if this was a freak thing that just happened to me.
    Mar 2015
    Harvey, LA
    300
    Talked to Don this morning, new cell should be here Friday.
    22,543
    Is that a mold line where the leak is? It looks like a pinhole to me as well.
    There was a thread a while back where a cell separated at a mold line enough to leak.
    I'm glad they're replacing it and your great video no doubt helped them see the problem.
    Mar 2015
    Harvey, LA
    300
    No, it wasn't on a mold line...it really seemed bizarre to me. At any rate, the new cell is in and working fine.
