Thread: New skimmer install question
    So I'm getting a new skimmer during a remodel and my PB put a extended throat in today instead of setting it back so now the opening at the skimmer will be flush with the wall instead of a tapered opening with concrete, is there any difference, I would assume I would get more skimming action of the skimmer is set Back and built up as a V for the entryway, Did I loose you guys?
    It's not too late to have him change.
    Here's a pick of what I mean.
    Am I being ocd? Opinions wanted please.
    Roth
    13000 in ground Wet Edge Satin Tahitian Blue, Pentair VS pump, Hayward DE4820, Hayward Vac, Pentair SWG IC 40, Pentair Intellibrite 5G, Intellibrite Controller,
    TF-100 Test Kit, Seminole, West Central Florida
    Jul 2015
    Roswell, GA
    69
    Re: New skimmer install question
    Someone else can speak to the physics and water tension/speed, but I will say I get some leaves that stick on the cover/surround that would likely not with a 45 degree throat. That said, doesn't kill me either.
    11k gal ig vinyl, Pentair Superflo VS, Heyward 3030 cartridge filter, dolphin 4 deluxe.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Well it's like a wide mouth Skimmer, I like it, have one...
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    30,431
    I guess there was a reason for him to narrow down the opening, right? What was it?
    Idk the one he took out was this, I should of told him what I wanted but never thought about it as I was obsessed more with the cracks. This was the old one so he just replaced what I had, hindsight should I have him rip it out now while the pool is empty and under repair, whatcha think?
    30,431
    Ask him. He may have had a good reason for doing so. If he did, I would leave it. Looks like he did a pretty nice job.
    Technically, not much difference that I can think of.
