Thread: Will top poles straighten when filled?
    Aug 2015
    Jonesborough, TN
    7
    I have a 9'x18'x4' pool that I'm filling. For the 2nd time. The first time, it was wayyy off. My brother and I built a wood frame and leveled it. Filled it with dirt and using 2 2x4x12's screwed together, we leveled the dirt the best we could all the way across. It has about a foot of water in it now and the sides are bowing in like the last time. I measured the water in all 4 corners. One of the 9' sides is 12" in both corners. The other 9' side is 11" in both corners. Please dear God tell me that's not too much of a difference. Will the frame poles straighten up as the pool fills?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Will top poles straighten when filled?
    If you have ADDED dirt, good luck. You should always dig down from lowest to highest points.
    domct203's Avatar
    Jun 2015
    CT
    3,578
    As mentioned if you tried filling the low spots instead of digging down the high spots there is no telling how that pool will settle once full (@ 42" of water there will be over 17 TONS of weight in that pool, about 35,000 pounds).
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Jimmy, it is really hard to level that way, it "can" be done but you have to use water and a plate compactor to level 1 inch at a time.. this will still not guarantee it will not settle as the weight of the pool/water goes in...
    that is why we recommend digging down the high sides level with the low areas.
    I did both, dug down and then built up with 1 inch screenings and sand
    Aug 2015
    Jonesborough, TN
    7
    To answer my own question, yes they straighten out when the pool is full.20150816_174440.jpg
    Coleman 9x18x4' above ground pool.
